vtec-e harness question/sensor question
i jsut got me a vtec-e engine. and i need the engine harness. i know a EX would do.
but there is a sensor that is at the top left of the engine. by the vtec solenoid. does that only come on the vx harness? what is that sensor. will i be ok if i just use a ex harness and not plug in that sensor, or will i have to hard wire it?
just wondering basically if i need the vx harness or not. i also havwe the ECU.
i can hook it up. i just need the propper harness then. will the car run right with just a ex harness? withouth the egr hooked up? i'm interested in hooking it up. can it be done seperately? is therea by any chance a write up hon how to run the wires for it. i doubht i'm gonna firnd a vx harness. i'm gonna end up with a ex harness.
any help is apreciated.
BTW that thing goes on the firewall has a plug and vacuum lines how does that hook up?
im confused.
im confused.
That wiring comes from the cabin harness. VX harnesses are altogether weird. I actually have a cabin harness (headlight plugs were cut off, previous owner hard wired HIDs) and a pretty thrashed VX engine harness (bunch of connectors are cut, most of it I can fix, I pulled the vtec wiring from it to turn a DX harness into an EX/Si harness) if you have any intrest i'd sell both quite cheaply, PM me if you're interested.
It can be done seperately, theres no write up that I know of
will the still be good without the EGR?
JDMInspired
Honda Civic (2001 - 2005)
Mar 10, 2008 06:30 PM
Mugen112
Jul 12, 2005 09:25 AM
