How do you remove third brake light in an '00 EX coupe?
Had smoke pouring out the hole in the trunk looking toward the light, pulled the panels off in the cab and saw that the previous owner had pulled it all out too and broke almost every non removable clip. Their solution; To shove their socks under the c pillar panels till it was at the right height.
. And for some reason they shoved a sock right in front of the third brake light bulb too.
The ending: the sock started to burn and I left work thinking it was an electrical fire. It smells like **** and I can't get the third brake light out of the plastic. I got the bottom screws out but there are two screws in the brake light cavity that I can't get to with a conventional phillips head. Help please.
. And for some reason they shoved a sock right in front of the third brake light bulb too.The ending: the sock started to burn and I left work thinking it was an electrical fire. It smells like **** and I can't get the third brake light out of the plastic. I got the bottom screws out but there are two screws in the brake light cavity that I can't get to with a conventional phillips head. Help please.
Nevermind, kinda found it out. Broke clips but it's held in by screws too so no big.
Last owner of my car was a straight dumbass.
xunkn0vvnx
Apr 29, 2017 12:56 PM
