oil pan gasket
Old Aug 26, 2010 | 05:47 AM
Kris's turbo's Avatar
Default oil pan gasket
Can you use a oil pan gasket from a eg on a ek? the gaskets for the eg look like a better gasket. Thank you for your input.
Old Aug 26, 2010 | 06:03 AM
dpetro1's Avatar
Default Re: oil pan gasket
can you be more specific about which engine? Eg and EK covers about half a dozen different engines. i'd assume some may be interchangeable
Old Aug 26, 2010 | 06:30 AM
Im replacing the gasket on my sister d16y8, I have a new gasket from a d16z6 will the gasket from the z6 work on the y8?
Old Aug 26, 2010 | 06:42 AM
xXx Justin xXx's Avatar
yes. as long as you're staying with d series to d series or b series to b series thay are interchangable.
Old Aug 26, 2010 | 09:06 AM
Former User's Avatar
This is not completely true. The oil pan gasket for the D16Y7 is very different than the gasket for the D16Y8.
Old Aug 26, 2010 | 01:29 PM
thanks for your help guys
Old Aug 27, 2010 | 05:21 AM
Really... did not know that. I thought all the d series oil pans were interchangable, therefore forcing the gaskets to be very similar... does that mean the y7 and y8 oil pans or not interchangable as well?
Old Aug 27, 2010 | 05:42 AM
Even though the two pans require different gaskets, the pans are interchangeable between Y7 and Y8/Y5 blocks.
Old Aug 27, 2010 | 05:57 AM
EJeff8's Avatar
Does using the Y8 offer some statistical gain in anything? Because I have a Y8 mini me and I'm pretty sure a Y7 oil pan. I just say this because usually, anything Y8 trumps anything Y7
B16EJ
Sep 25, 2015 08:15 PM
dth0ng69
Jul 14, 2009 08:28 PM
ringgold
18
Sep 20, 2004 04:28 AM
James
May 11, 2004 01:38 PM
