2.5" to 3" turbo outlet downpipe
Old Aug 25, 2010 | 09:09 AM
2000SICVC's Avatar
Default 2.5" to 3" turbo outlet downpipe
I have a turbo that has a 2.5" turine oulet and I want a 3" downpipe. What is the best approach to take:
a) weld 2.5 to 3 inch reducer to turbo exhaust flange and 3" downpipe
http://cgi.ebay.com/ebaymotors/Pipin...ts_Accessories
or
b) V-band 2.5 to 3 adaptor. Looks like alot more money and possibilities for leaks. How are you guys coming off of your turbos into 3" downpipes?
http://cgi.ebay.com/ebaymotors/2-5-4...ts_Accessories
Old Aug 25, 2010 | 09:34 AM
NonovUrbizniz's Avatar
Loved
Default Re: 2.5" to 3" turbo outlet downpipe
Either one... Vband is more spendy and gives you some more wiggle room which is well worth it IMO.
I got a spoolin 3" DP that has a 2.5"-3" reducer flipped around and welded to the downpipe/Flange.
Old Aug 25, 2010 | 09:43 AM
ticaaal70's Avatar
AFI has a downpipe that starts up 2.5" and then grows to 3" I believe
Old Aug 25, 2010 | 11:23 AM
2000SICVC's Avatar
Is there anything wrong with bolting 3" downpipe w/ flange directly onto the hot side exit (2.5 Dia). I know there will be a 1/4" lip (stepped up) all the way around, but wont obstruct the air flow (but may cause some kind of turbulent effect). thoughts???
Old Aug 26, 2010 | 01:47 AM
redtegra's Avatar
that will be fine and the best way.
Old Aug 26, 2010 | 04:33 AM
Autoworks's Avatar
You can make 3" downpipes on T3 4 bolt/5 bolt flanges without the step reducer.
Old Aug 26, 2010 | 07:52 AM
Loved
it would cause turbulence but probably not the end of the world.
Old Aug 26, 2010 | 09:38 AM
96 GSR-T's Avatar
I just had my friend weld the 3" pipe right to the 2.5" flange no big deal, I used stainless "cap" bolts (type that use an allen key) because there was no room to get a socket on the flange bolts and it was all good.... make sure whoever welds it doesnt cake it up with filler rod or you will be doing a bit of grinding, we just fused mine with no filler at all.
Old Aug 26, 2010 | 09:48 AM
90Rexx's Avatar
holy crap dont bolt a 3 inch dp to a 2.5 outlet.
look at garrett's GT style exhaust housings, its a gradual reduction, thats the best way to go.
Old Aug 27, 2010 | 05:20 AM
2000SICVC's Avatar
Now we're getting somewhere...
What GT style housings are you talking about? The turbo I have is a GT3271, so it is a GT style turbo.
Old Aug 27, 2010 | 05:35 AM
Civicman86's Avatar
For best flow do not bolt a 3" to a 2.5" outlet. The science behind it is boring but you will not get the best flow. That being said the difference is probably minimal, and unless your racing hardcore then you would probably not ever know the difference.
I would go to a 2.5" and gradually increase it to a 3".
Old Nov 26, 2010 | 09:04 PM
criticallistenp's Avatar
A 2.5" collector bolted directly to a 3" exhaust WILL interrupt the laminar flow of exhaust up to that point AND if you are hoping to maintain exhaust scavenging for performance, the interruption of this laminar flow by turbulence will diminish, if not negate entirely, the benefits that are achieved by exhaust scavenging. So, yes, bad for flow. It is best to increase diameter slowly over duration. I'm not sure if their is such a product available, but it would be optimal.
Old Nov 26, 2010 | 09:08 PM
http://www.sfxperformance.com/parts/VIB2630.htm
Check that link out. See if it works.
Old Nov 27, 2010 | 07:28 AM
onefstek's Avatar
http://www.advancedstreetperformance...iy_exhaust.php
roller3804
Feb 21, 2012 02:54 PM
EdSales
Dec 27, 2009 10:15 AM
Honda4life777
Jun 28, 2009 08:43 PM
Topdawgg
Feb 8, 2006 03:11 PM
Andrew 825SM
Jun 20, 2002 11:59 PM
