Need help with 1996 accord timing!!!
Old Aug 24, 2010 | 03:28 PM
45js45's Avatar
Default Need help with 1996 accord timing!!!
I am trying to put our non vtec back in time after replacing timing belt.The car starts but we didnt mark the dist. before it was removed.What is the ignition timing supposed to be?
Old Aug 24, 2010 | 05:18 PM
phootbag's Avatar
Default Re: Need help with 1996 accord timing!!!
It should be on the underhood label.
Old Aug 24, 2010 | 05:40 PM
45js45's Avatar
i have read that the timing is adjustable and also that it is not....I am confused.The car will run....just very rough.If I hold my foot gently on the exhaust it will try to rev up alittle,but,then it starts to surge.
Old Aug 24, 2010 | 06:14 PM
tamadrummer1120's Avatar
the timing is not adjustable through the distributor. the car is obd-2, therefore the 'distributor' is more or elss not really like a real distributor, but just early stages of electronic ignition.
are you sure the timing of the engine is correct. sounds like it is a tooth or two off.
Old Aug 25, 2010 | 02:00 PM
Acorn's Avatar
Did you mess with your distributor? If not just leave it alone. I never touched mine when I changed my timing belt.
I would double check your work, rotate the crank pulley so the marks on the pulley line up with the mark on the lower cover, then check if the cam gear is at tdc (arrow pointing up, two marks on each side).
Did you put your balance shaft at tdc and lock it in place?
Old Aug 25, 2010 | 02:03 PM
45js45's Avatar
We had to remove the distributor due to rebuilding the head.Is the arrow on the cam pulley arrow supposed to be straight up with the head or with the ground.Hope that makes sense.
Old Aug 25, 2010 | 02:21 PM
Acorn's Avatar
Straight up with the head I think, but to make sure its in the right place there are also two notch marks on each side of the cam gear that should be aligned with the top of the lower cover.
bnwbass
May 14, 2016 12:37 PM
alperx
Engine Management and Tuning
Jun 7, 2011 05:00 AM
tobster
Aug 20, 2010 05:55 AM
brusk13
Jan 11, 2006 07:01 PM
krazn
Feb 22, 2004 11:11 AM
