manual to power windows swap help!!!
Old Aug 24, 2010 | 11:13 AM
Bartman201's Avatar
Icon2 manual to power windows swap help!!!
Ok I'm doing a manual to power window swap. My car is a 1995 civic Dx hatchback, I got 2 1995 civic ex donor doors. Now I know I need the floor harness so my power Windows an locks will work. My question is can I use the floor harness from a 1995 aura integra?
Old Aug 24, 2010 | 11:38 AM
rickkane's Avatar
Default Re: manual to power windows swap help!!!
How much wiring do you have from the donor car?
Old Aug 24, 2010 | 12:15 PM
Bartman201's Avatar
Is
They unplug them so the doors got all the plugs.
Old Aug 24, 2010 | 01:15 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Actually, I'm pretty sure you can.... but you should check each wire pin by pin. But ... the 92-95 Civic and the 94-97 Integra share the same fuse box so it should be pretty easy and will work. You can also use the floor harness from a Civic 4dr with power options which are a little easier to find in j-yards. Hey if you're pulling **** from an Integra, you should also do this retrofit: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bdiy%5D-oem-92-95-honda-civic-lights-chime-retrofit-no-radioshack-crap-here-folks-2749779/
Old Aug 24, 2010 | 02:02 PM
Bartman201's Avatar
Originally Posted by DeSchlong
Actually, I'm pretty sure you can.... but you should check each wire pin by pin. But ... the 92-95 Civic and the 94-97 Integra share the same fuse box so it should be pretty easy and will work. You can also use the floor harness from a Civic 4dr with power options which are a little easier to find in j-yards. Hey if you're pulling **** from an Integra, you should also do this retrofit: https://honda-tech.com/forums/showthread.php?t=2749779
the guy selling me the doors has a 95 4 door civic ex and a 95 teg but he told me the floor harness from the 4 door ex will not work. So I can use the floor harness from the 95 4 door ex or should I use the 95 refs harness?
Old Aug 24, 2010 | 02:17 PM
deschlong's Avatar
Loved
Community Favorite
USDM 4 door LX/EX power harness will work - **** it's like nobody ever reads my DIYs. I know because this is what I used myself for my own retrofit.
Old Aug 24, 2010 | 03:55 PM
Bartman201's Avatar
i believe you. i just dont like messing with electrical stuff so i ask 5 times before i touch it.
TylerB
11
Jul 30, 2009 10:20 PM
OTiS515
Jun 29, 2009 10:09 PM
alexg103
Nov 11, 2008 04:49 PM
2 Loe 4 Fat Hoes
May 8, 2005 10:51 AM
