Wet sump oil setup on a B series
Old Aug 24, 2010 | 09:44 AM
Demogerg's Avatar
Default Wet sump oil setup on a B series
Question: Does anyone have any good technical information on a wet sump oil setup for a B series motor?
Background information: I have an LS-vtec powered EF with the all-to-frequent oil problems associated with it (I got the motor from a friend, and I dont think he took out the oil plug on the head) and I have a turbo that I am planning on installing in a few weeks. Before I install the turbo I want to fix the oil problems so I dont exacerbate the problems with the extra oil feed line going to the turbo. Assuming that I remove the plug from the head and that more of less solves the vtec oil pressure problem, would a stock oil pump feed enough oil for a TD05-18G turbo and vtec?
I had been thinking about doing a dry sump setup for a while, but I have heard that B18 bottom ends don't suffer from windage issues, and that a wet sump setup is cheaper while being just as effective. Does anyone have any good advice for a solution to my oil problem?
The car will get its runs as a daily driver, a drag car, and a circuit car, so keeping it reliable is critical, and power is secondary.
Old Aug 24, 2010 | 10:30 AM
kyden's Avatar
Default Re: Wet sump oil setup on a B series
you have to use the plug on an ls/vtec conversion since the block does not have an oil hole to supply the oil to the head.
Dual Cam Killer
Dec 12, 2009 06:37 AM
MidwestAutoWorks
Sep 7, 2008 05:59 PM
redlseg
May 14, 2005 03:10 PM
dave'sh22a4
Jan 21, 2003 07:41 PM
