Transmission & Drivetrain Gearboxes, Differentials, Clutches
Shredded Y8 final drive, why?
Old Aug 23, 2010 | 12:21 PM
94EG8's Avatar
Seagull Management
Default Shredded Y8 final drive, why?
I had someone drop off a Y8 tranny to me the other night, guy said it was making noise and clicking, but that it had been working fine otherwise. I figured it need an ISB or diff bearing. Pulled the case to find that 4 teeth were gone off the countershaft and every 4th tooth on the ring gear was chipped. What I don't get is all the bearings were good, there was no way the countershaft or differential walked. Diff was good, no signs of wear on the diff pin or spider gears. He said he was just driving through town and it started clicking. I know the car has seen the track before and was probably launched hard. That said its a stock Y8 and as far as I can tell the transmission has never been apart before, looks like factory hondabond. It looks like the plug for the snap ring was out before, but i'm guessing someone thought it was the fill hole. Anyone have any insight into what caused this? Pics of the carnage below:
Old Aug 23, 2010 | 12:34 PM
Aquafina's Avatar
Default Re: Shredded Y8 final drive, why?
The CSB had walked about, but that didn't cause it.
It's a stock FD, which is one of the three big weak points in the D trans.
Old Aug 29, 2010 | 08:57 AM
random-knight's Avatar
This is my transmission :D
Old Aug 29, 2010 | 10:23 PM
Mista Bone's Avatar
D Tranny Guru
wheel hop at launch cracked a tooth, which later ended up in the gears.
Old Sep 8, 2010 | 07:38 AM
Bense's Avatar
Is it really? Or are you just making a biased post because you happen to sell aftermarket final drives?
Old Sep 8, 2010 | 11:29 AM
Honda Bull's Avatar
This. And as Aquafina said, you'll need to push that CSB down and post it, provided it's still in good shape.
He's correct. For the B- and D- series, the final drive (countershaft/ring), differential, ISB, and upper CSB all give the most problems in terms of mechanical failure. The older D's also have those shitty, cast aluminum shift forks that snap fingers off.
Old Sep 8, 2010 | 11:45 AM
Aquafina's Avatar
Not biased. I have a bin full of broken stock FD's, diffs, and shift forks.
Old Sep 9, 2010 | 05:02 AM
94EG8's Avatar
Seagull Management
To anyone that wondered we ended up getting another Y8 tranny with a bad ISB, everything else looked like new, syncros, hubs, sleeves and gears all looked perfect. So we replaced the ISB and all the seals and put it back together. Transmission shifts good but there is still some minor bearing noise, so its coming back apart. Should have replaced all the bearings but we're trying to do this cheaply and everything else felt great, smooth and no play.
Old Sep 11, 2010 | 11:15 AM
Great Job Eric... works better then my first Y8 tranny :D
Old Sep 13, 2010 | 02:23 AM
77amc's Avatar
In the old civics and accords I've had good luck with just flipping the bearings around (to get a slightly tighter tolerance for that particular bearing) and popping them back in.
BUT, that was "On the cheap" and a LLoong time ago, when it was easier to pull a trans.
E
Old Sep 13, 2010 | 03:38 PM
94EG8's Avatar
Seagull Management
E
I haven't pulled apart anything older than a 5th gen D-series tranny so I really can't comment on anything older, but I can tell you for this stuff and pretty much anything newer the bearings have to go a certain way for a couple of reasons, one is oil flow, the cage is different on one side than the other, flipping them around starves the bearing for oil, and the outermost countershaft bearing has a groove cut in off center for the snap ring.
Old Sep 13, 2010 | 07:56 PM
Aquafina's Avatar
That and some are tapered.
Stuominous
Mar 18, 2014 07:14 AM
mienboiracer209
Dec 10, 2004 08:20 PM
fishnfst
Jun 6, 2004 08:23 PM
mRek9R
Mar 10, 2004 05:24 AM
spencedogg
Aug 10, 2003 05:59 AM
