FS/FT 97 vsm coupe BUILT TURBO D "project" $3000 Nebraska
97 auto to manual swap silver civic coupe, has dents here and there all one color etc..
have to swap:
hx manual cluster
clutch slave/master cylinder
clutch pedal assembly
Disassembled the block from the head for pictures
Built D16 vtec
75.5 vitara
fj i beam rods
arp rod/head bolts
zex valve springs/cam 59500 stage 3
acl bearings
acl thrust washers
hasting piston rings
oem water pump
oem y8 head gasket
new oem valvetrain,seats,gaskets
z6 dizzy, new cap rotor plugs
crank micropolished
intake ported
head port/polished
block notched
Z6 p20 y4f tranny
new synchros, bearings
LSD motorsports dragger clutch
z6 oem flywheel newer
Low miles, when i say new its roughly 2000 on everything.
cv shafts, still need linkage
turbo kit
rev hard/drag manifold brand new
t3 garrett m4 turbo (disassembled)
hks ssqv bov
tial 38mm wastegate
piping,intercooler, couplers, tbolts
dsm 450cc injectors
oil feed line
1 used sandwhich plate, 1 new
boost gauge with pod
EVERYTHING NEW IN THE TURBO KIT EXCEPT feed line, turbo, injectors
I have also...
obd2a virgin vtec harness
obd2a to obd1 harness
p28 ecu virgin
ebay short shifter
energy shifter bushings BNIB
arizona race and machine mounts BNIB (awaiting for them to ship) 70a bushings just like hasports
possibly other stuff but this is the majority of it.
Also have a complete Y8 head with 79k miles
z6 head complete internals
Mounts will be included if I receive them (seller F'd up)
Car is in project stage right now so the front end is off, still has auto set up on it
Car is a 6-7 out of 10 on the exterior
Interior is 9 out of 10
$3000 firm or trade for clean honda (plus cash, swapped, ac, etc.. something CLEAN AND READY)
Can take out some things to lower the price but mostly would like to sell all my honda stuff. Also you will notice the vents are cracked/no radio. I have an oem honda radio and mint climate control/vent's.
Trades 96-00 civic 2 door, hatch, 4 door (manual and with a/c)
94-01 integra gsr
01-05 civic sedan, coupe, hatch
Possilbly others
Negoitable on cash on my end or cash on your end with trade only. Price for everything is $3000 and must be towed by you, I can't tow it sorry. Everything is legit and needs very few things to be a complete street beast.
Bump it up for a sleeper SOHC
have to swap:
hx manual cluster
Built D16 vtec
75.5 vitara
fj i beam rods
arp rod/head bolts
acl bearings
acl thrust washers
oem water pump
oem y8 head gasket
crank micropolished
intake ported
head port/polished
block notched
Z6 p20 y4f tranny
turbo kit
hks ssqv bov
tial 38mm wastegate
dsm 450cc injectors
oil feed line
I have also...
p28 ecu virgin
ebay short shifter
94-01 integra gsr
Possilbly others
I stress best offer, really need cash soon. If anyone wants, they can put 1.6 in it, keep it auto with a/c, sell it part the rest, make some money! I don't care, need it gone.
