d16z6 overheating - already replaced temp switch, radiator, thermostat
hey so ive been over heating alot latley ive changed temp sensor,temp switch,radiator,thermostat...yesterday i was driving the temp gauge in my car went up but i the was running for maybe 1.5 minutes so i knew the actual coolant itself wasnt hot but my gauge went up and the head gasket let go...my question is could it have been the gasket the whole time
Hey so i took the head off and all looks to be ok...my next question...what could have caused my temp gauge to sky rocket even though i started and drove the for maybe 3 minutes?
ok I hope this help you. Check if your radiator fan works .I know you put a new thermothat but some time they don't work specially when you buying on autozone which sensor you replace the one on thermothat or the one on the head .
I replaced both sensors, head and thermostat...my thermostat worked when I first started it up everything worked fine then but the fan only turns on sometimes I've noticed
You should wire the fan to a switch and make sure it works like it should. Yiou can go to the parts store and get a slim fan for under $100 (probably even cheaper than that).
This it very true I was having similar problems after doing an engine swap with over heating. I had no leaks,coolant was full and the fan worked just fine replaced all the sensors and come to find out It was something as simple as bleeding my coolant system. Start with the cheap and simple stuff first lol
too check the complete fan system, disconnect the fan switch and use a paperclip to touch both terminals on the disconnect. the fan should should turn on right away if you have the car on, if it doesnt hook up the fan directly to the battery if it works its probably the relay if it doesnt the fan motors done. but since its heating up rediculously fast its probably the water pump
one thing i noticed that hasnt been brought up. check ur water pump i had a similar issue and my water pump was leaking like crazy and i thought it was water condensation off my ac line.
pro306
18
Jul 4, 2013 05:35 AM
nonvtec92
15
Nov 16, 2008 01:19 PM
car, civic, d16z6, fan, honda, hondatech, hot, overheating, replaced, responsibility, switch, temp, thermostae, thermostat, vtec
