OVERHEATING :(???????
Old Oct 23, 2005 | 09:20 AM
mugencivic94's Avatar
Default OVERHEATING :(???????
recently put a greddy 15g kit on my d16z6 and last night i noticed my heat gauge right at the hott mark so i pulled over and let it cool everything drives fine no smoke no leaks where i can see put while driving the temp goes down could this be the thermostat or because the intercoolers blocking the cold air from the radiator or what else could it be any help would be great thanks.
Old Oct 23, 2005 | 09:29 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: OVERHEATING :(??????? (mugencivic94)
POP goes the headgasket.
Old Oct 23, 2005 | 09:31 AM
s2kdre's Avatar
Default Re: OVERHEATING :(??????? (boostincoupe)
check ur fan, make sure its set up right as a puller or pusher if u had to go to a slim fan.
Old Oct 23, 2005 | 09:55 AM
Default Re: OVERHEATING :(??????? (jdmhonda)
how would it be the head gasket?
Old Oct 24, 2005 | 05:42 PM
wisjdmhonda's Avatar
Head could be lifting under boost. If so, get a new oem headgasket and arp headstuds and that should cure the problem. Is your coolant overflow resiovour over filling?? I had that prob when I had my d16z6.
steggun revned
K Series
Feb 21, 2014 04:56 PM
uselesshuman
17
Sep 5, 2010 06:43 AM
bigapple427
Jun 19, 2006 02:33 PM
mikehawkBUiLT
15
May 14, 2004 09:49 AM
orido 1.6
Apr 12, 2004 05:45 AM
