vtec swap with no vtec
Old Aug 22, 2010 | 08:05 AM
wolf95's Avatar
Default vtec swap with no vtec
Ok, so I swapped an obd1 d15b vtec with a p28 ECU into an obd1 del Sol S with a P06 ECU. The motor ran with vtec before we did the swap and now Vtec won't kick in. I followed all the wires for the Vtec solenoid and pressure switch and they seem to be going to the correct area. I thought I'd have to wire up the wires since the previous motor did not have vtec in it (S model) but the wires from the engine harness to the ECU are all there and set up for vtec.... but it's still not kicking in....
I double checked my ECU pinout and the orange/white wire is going into the A4 pin and the orange/blue wire is going into the D6 connector and the black ground wire is going to the ground point on the water outlet housing... HELP!!
Old Aug 22, 2010 | 08:07 AM
300whpej's Avatar
Default Re: vtec swap with no vtec
reverse the 2 wires on the ecu and see what happens
Old Aug 22, 2010 | 08:17 AM
Green Crack's Avatar
Are you throwing any codes?
Old Aug 22, 2010 | 08:18 AM
wolf95's Avatar
nope. not a single code.
Old Aug 22, 2010 | 09:46 AM
wolf95's Avatar
I'll try switching the wires around tonight
Old Aug 22, 2010 | 08:39 PM
wolf95's Avatar
bump
Old Aug 22, 2010 | 10:21 PM
ricky00's Avatar
speedometer working?? check ur vss
Old Aug 22, 2010 | 10:33 PM
raidacaipo's Avatar
x2
If you have no CEL for vtec solenoid or pressure switch then check the fuse for the vss/alternator. To figure this out, your speedometer should not be working..
Old Aug 23, 2010 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
What RPM's is the motor reving up to? If it goes all the way to 7200 its working.
Old Aug 23, 2010 | 11:28 AM
wolf95's Avatar
the speedo works fine. and it's revving out all the way. there's just NO kick when it should kick in but it did before the swap.
Old Aug 23, 2010 | 11:43 AM
Technical Hero
The best way to go about it is to hook a 12V activated light on the VTEC solenoid and somewhere you can see it and see if it lights up at the designated RPM's, if it does VTEC is working.
Old Aug 23, 2010 | 01:10 PM
300whpej's Avatar
did you switch the wires on the ecu?
Old Aug 23, 2010 | 01:19 PM
raidacaipo's Avatar
This is a stupid question but is there enough oil in your motor? Double check that.
Heres what you should do. Unplug the vtec solenoid wire plug. Start the car and drive it around. See if the check engine light goes on for code 21 or 22. If it doesn't then theres your problem. Either your ecu doesnt look for a vtec sensor meaning its a non vtec ecu or theres something else wrong with your wiring..
Old Aug 23, 2010 | 02:16 PM
ricky00's Avatar
are u using the p06 ecu? cause thats a non vtec ecu
Old Sep 2, 2010 | 11:31 AM
wolf95's Avatar
sorry for taking so long to reply. I am using a p28 ECU.
I put in a 98 civic dx (non vtec) Oil pressure sending unit in the motor for the swap that I had laying around. I went to advance a few days ago and got a 94 del Sol Si Vtec OPSU and we suddenly HAVE vtec...
The part numbers are all the same and i didn't think it would make a difference but somehow it does. I raced her the other night (legally of course.. ) with my z6 and she freakin crept in front o me...... >_< lol
So how would it make a difference? Could the old one just have been bad?
Old Sep 5, 2010 | 06:26 AM
wolf95's Avatar
bump?
Old Sep 5, 2010 | 08:25 AM
ricky00's Avatar
are u sure vtec is not kicking in.. if u say u can take it all the way with no problems, than vtec should be working.. maybe u just dont hear it.. try unbolting ur headers n do a quick run.. u should be able to hear the crossover
jdm.coupe3234
37
Dec 11, 2009 08:19 AM
4 door beast
Mar 3, 2009 10:47 AM
jetoutant
11
Jan 2, 2008 07:50 PM
sedrohatchstyle
Dec 15, 2007 08:11 AM
SuperNemeSis
Mar 29, 2003 02:32 PM
