motor help
motor help
ok so i pulld the motor out of my 00 ek and dropped it into my sol.. after i did the swap i had to wire a few things up.. afte i was done with everything i took it for a test drive and for some reason it wont go passd about 1700 rpms.. so i checkd the ecu codes and i was only throwing code for my vtec solenoid and iacv so i wired up the vtec and plugged up the iacv and its still doing the same thing anyone know whats wrong with it??
1 Post
Re: motor help
Plugged up the iacv; but is it wired right? Iacv alone shouldnt cUse this but maybe you have other cels in the memory.
Did you clear the memory?
Did you even HAVE cels?
Re: motor help
after i did the swap i had cels for vtec solenoid. vtec pressure switch. and iacv.. i used anon vtec harness so i had to wire up the vtec.. and i wired up the iacv.i reset the memory and after that i had no more cels but still acting the same
Re: motor help
at about 1700 rpms it starts to bog down real bad.. and if i barely give it gas i can get passd the 1700 rpms to almost 3k rpms.. but if i give it regular throttle of give it alot of gas it will bog real bad
Re: motor help
it sounds like your fuel injectors are clogged or not running right, do you have a fuel pressure gauge? have you checked to see if you have fuel pressure?
Re: motor help
well when i pulled the motor out of the ek the motor was running like achamp.. swapped it into the sol and was not running good .. but yeah i havnt got a fuel pressure gauge i will need to get one
Re: motor help
wait its from a 00 EK? that means its OBD2B, did you change the OBD2 B stuff? or did you wire it in inside of the del sol, because i know the OBD2B thing has more sensors and stuff that could be making it not run properly.
Re: motor help
well the motor is a d16z6 which originally is a obd1 motor.. when i got the ek the motor was in it and was running fine.. but then someone hit my ek and ran so i was stuck with just the motor pretty much.. i had the sol sitting there so i dropped the z6 into the sol
Re: motor help
Re: motor help
well when it was hit it was hit on the frontpassenger headlight.. so the passenger fender hood and bumper was damaged pretty bad and my core support was pretty bent.. but it was hit about 10 miles from my parents home so i drove it to their house with no problems at all.. so the motor wasnt damaged during the wreck
Re: motor help
Re: motor help
i used a non vtec harness cause couldnt get a hold of a z6 harness... so i had to wire up the vtec.. but its not my first time wiring up the vtec so i know i did it right.. and the sol had a SiR2 b16 in it and was just pulled about 3 weeks ago so impretty sure the fuel filter/pump arent bad considering the sol was running fine
Re: motor help
my best advice is to just go over the engine bay again and make sure everything is plugged in and pull out the spark plugs and make sure there all good and make sure the wires are snug... i mean it sounds like your missing something, but the bogging while going is really making me think the timing is off ... does it feel like its missing fuel or getting too much fuel? cause there is a big difference there
Re: motor help
feels like its missing fuel.. when car is on and not in gear it idles fine.. oh and if its not in gear and you give it has the car will start to bog around the 1700 and it will backfire
