2001 civic axle help please
How do you put change the axles on a '01 civic? Got the old out and new in but can't seem to get the ball joint to line up. Do you need to remove the shocks to be able to swing it over? Do you need to remove the sway bar? I'm stuck trying to finish this so help is appreciated. Thanks
The end link, yes. But you don't have to remove the whole thing. Just disconnect the bottom half from the control arm.
Is the axle pushed all the way in at both ends?
exsquid
May 3, 2008 10:23 AM
