axel removal eg!
axel removal eg!
this is my first swap and i tried searching axel removal but can seem to find any! well i disconnect everything that was connected to the motor but the only thing holding me back is the axels! i removed the axel nut is it? correct me if im wrong! it was pretty hard to remove it but manage to get it off !! but anyways heres the part i need help on how do i remove the axels?? please help me out thanks!!
please keep negative comments to yourself thanks!!
take off lower ball joint nut, take a hammer to the lower control arm to get the ball joint to pop out. pull the knuckle away and pull the axle out, may have to use a pry bar on the back of the axle.
im sure there is how to's on here somewhere.
Resident Gearhead
Thank B18C5-EH2 for this great tutorial:
https://honda-tech.com/forums/showthread.php?t=382416&highlight=axle
You don't need to do anything with the upper ball joint or the tie rod end. Sounds like an unorthadox method
thanks mcvtec!! this helped alot!!
White_EG1
22
05-21-2018 10:20 AM
C_Rock77
08-27-2008 11:19 AM
