Need a good machine shop in the M-A region
Alright well I have everything I need for my motor beside ACL race bearings and a head gasket. I need to find a good machine shop to take the block and head to. I need my b18c1 block bored from 81mm to 82mm for my 82mm rs machine PR-3 pistons, also need the rods, bearings, crank, ect installed in the block along with making sure the block and head are flat. I'm also thinking about having the shop go ahead and install my valves, crower valve springs & ti retainers, and skunk2 pro2 cams into my b16 head. Then I will get the head and block back and install the golden eagle head studs & head gasket and drop the head onto the block, torque it down, install the oil/water pumps, timing belt/tensioner, distributor, etc...
I'm from the Hagerstown, MD / Greencastle, PA area.
So does anyone know of any good machine shops around my area that I
can have do everything I mentioned above? My one buddy told me the NAPA machine shop in Waynesboro, PA does good work and has pretty good prices. I'm just kinda leary of having NAPA do my motor lol.
Any help would be greatly appreciated, thanks in advance.
Justice Racing Engines is about 1 hour from you. They have tons of experience with hondas.
http://www.justiceracingengines.com/index.php
Denny Willey is in Newville, PA...great guy and very knowledgeable...about an hour north from where you are and he very reasonable with price!! 717-776-6835
yes sir
Christopherian1982
Feb 26, 2009 05:42 AM
ntrider
Dec 14, 2006 10:21 PM
