distributor wiring
hey i'm tring to wire up a obd2 motor in a rex and got everthing hooked up but the distributor i need to know which wires go were on the obd0 harness got the blue,blackand yellow, just need to know the rest of the wires i dont have a 96-up repair manual i just need the obd2 shematic for the distribuotr
[Modified by ef civic, 2:23 PM 9/17/2002]
Match the colors, there the same. Actually there might be one odd color but i cant remember off hand
But I know I just matched the colors . I run a 99 gsr dist in my crx and had to repin it with the obd0 plug. If you can wait till thursday I will check my garage because I luckily drew a diagram. IM me
Ok hold the connector looking at the back where the pins push in. hold it so the mounting tab portion is at 12 . this is the wire placement.
.................O empty
Owhite blue Owhite Oblue yellow
Opeach blue Opeach Oblue green
.................. Oyellow green
The other connector just match the colors .
[Modified by Tbone, 8:15 PM 9/20/2002]
Project H
12
Apr 5, 2019 12:18 PM
