timing question
Old Aug 21, 2010 | 08:53 AM
miguey310's Avatar
Default timing question
well i'm going to change my head on my 91 stock civic and i was wondering if the timing would be off or anything or the timing would be good
thanks in advance
Old Aug 21, 2010 | 08:56 AM
Projekt_Ef9's Avatar
Default Re: timing question
As long as u line up the timing gears correctly it should be fine but i would still check it to make sure before driving it
Old Aug 21, 2010 | 09:14 AM
Jockone's Avatar
Timing belt has to be removed(at least from the head) to get head off.
Sounds like a good time to change the belt and might as well do the water pump while you are at it.
Old Aug 21, 2010 | 09:20 AM
Dark_Teg's Avatar
Timing belt will have to be removed....you will go ahead and replace it if you are smart. Find TDC and line all timing marks back up and re-install timing belt. You will then have to re-set your timing VIA a timing light. You have to let the car get up to operating temp and unplug the service port before you can set the timing.
boomersz
Mar 4, 2007 07:55 AM
bart2546
Dec 31, 2006 06:30 AM
speedaccordinly24
Apr 21, 2003 08:10 AM
