Engine won't start - no spark
I have a 94 civic dx with the stock motor(uggghhhh) i was driving today and notice that the engine stopped while i was moving didnt count it strange at all...so i tried to crank it up didnt crank...ok i open the hood and find that there is no spark at the dizzy so i replaced the rotary button still no spark...mind you the car had been having some idling issues it would rev up and down not high tho just noticable.. ok if there is anything i may have left out plz let me know
btw i had it compression checked before it went out..
the numbers were 120 113 115 119 left to right
Thread titles MUST be subject specific so that members browsing topics can understand the tech problem for which an answer is sought without reading the post:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Title edited for you this time.
If the fuel pump primes, check the coil and igniter unit in the distributor and whether the timing belt snapped.
Hey, I just bought an 1990 Honda crx si, and their has been so many problems. A wiring nightmare i should say. The car wont start now, and it shows its running rich. How can get the car to the ideal state, rather than the rich or lean?
please start your own thread and your questions will be answered in there. no thread jacking.
Use this,
http://www.team-integra.net/sections...ArticleID=1112
To test out the ICM and ignition coil.
thanks you guys turns out it was the coil...ok problem solved but a new one arose....when i turn on the god awful cold ac (thank ya Jesus) the car idles super low and acts sluggish was doing it before i change the coil
emfman
Oct 19, 2014 10:37 AM
biggmike2
Jan 21, 2004 10:56 PM
