Engine won't start - no spark
Old 08-20-2010, 10:23 AM
myfirsthonda199's Avatar
Icon7 Engine won't start - no spark
I have a 94 civic dx with the stock motor(uggghhhh) i was driving today and notice that the engine stopped while i was moving didnt count it strange at all...so i tried to crank it up didnt crank...ok i open the hood and find that there is no spark at the dizzy so i replaced the rotary button still no spark...mind you the car had been having some idling issues it would rev up and down not high tho just noticable.. ok if there is anything i may have left out plz let me know
btw i had it compression checked before it went out..
the numbers were 120 113 115 119 left to right
Old 08-20-2010, 10:45 AM
Former User's Avatar
Default Re: Hey guys im new to honda so i may sound stupid...
Thread titles MUST be subject specific so that members browsing topics can understand the tech problem for which an answer is sought without reading the post:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Title edited for you this time.
If the fuel pump primes, check the coil and igniter unit in the distributor and whether the timing belt snapped.
Old 08-20-2010, 10:57 AM
Default Re: Engine won't start - no spark
thx now the coil how would i deal with that? nd checking it...also the rotary button spins so that should eliminate the timing belt right
Old 08-20-2010, 11:02 AM
siCrx18's Avatar
Hey, I just bought an 1990 Honda crx si, and their has been so many problems. A wiring nightmare i should say. The car wont start now, and it shows its running rich. How can get the car to the ideal state, rather than the rich or lean?
Old 08-20-2010, 11:04 AM
mayfly's Avatar
please start your own thread and your questions will be answered in there. no thread jacking.
Old 08-20-2010, 11:05 AM
mayfly's Avatar
your problem is simple. its the ignition coil. its inside the distributor. it will be about $70 to replace. to test if this is the problem. try using a buddys working distributor, then if the car runs go buy your self a good ignition coil. goodluck
Old 08-20-2010, 11:38 AM
Green Crack's Avatar
Use this,
http://www.team-integra.net/sections...ArticleID=1112
To test out the ICM and ignition coil.
Old 08-20-2010, 10:07 PM
thanks you guys turns out it was the coil...ok problem solved but a new one arose....when i turn on the god awful cold ac (thank ya Jesus) the car idles super low and acts sluggish was doing it before i change the coil
Old 08-22-2010, 05:10 PM
honda_sanchez21's Avatar
check your alternator could be lack of power
Old 08-25-2010, 11:50 AM
ok could it be it going out slowly because i have been riding on it for a minute..
emfman
10-19-2014 10:37 AM
munchlax
06-16-2011 06:40 AM
1994turbocivic
02-10-2011 06:26 PM
gsrkid24
10-12-2009 05:37 AM
biggmike2
01-21-2004 10:56 PM
Quick Reply: Engine won't start - no spark
