What spark plugs are you running?
Old Aug 19, 2010 | 03:41 PM
93 Eg Couper's Avatar
Default What spark plugs are you running?
I have a D16Y7 with Z6 head turbo. Vitara pistons, Eagle rods.
I haven't started the motor yet, looking to make 220-260whp anywhere in that range would please me.. What spark plugs do YOU guys run and what do you recommend for ME?
Old Aug 19, 2010 | 03:53 PM
ralph11sec's Avatar
Default Re: What spark plugs are you running?
for your power. with about 7.5CR on 91 octane, bkr7e should be fine.
Old Aug 19, 2010 | 03:55 PM
laosonick's Avatar
brisk 7's
Old Aug 19, 2010 | 04:06 PM
I was thinking bkr7e's 0.28 gap
Old Aug 19, 2010 | 04:07 PM
Originally Posted by ralph11sec
7.5CR
im not sure what you mean by that...
Old Aug 20, 2010 | 08:58 AM
welfarepc's Avatar
CR is your compression ratio.
Old Aug 20, 2010 | 09:03 AM
EsotericImage's Avatar
Retired Moderator
That gap is rather large.. i would gap it at .20 -.22
I run NGK 4091's (7's)
Old Aug 20, 2010 | 11:43 AM
dpetro1's Avatar
a .028" gap should be fine. you only need to go smaller if you are blowing out spark. a bigger gap will give the car a better idle. also the 4091 are non-resistor. i think he would be better off with regular 4644, bkr7e like everyone else recommended.
i only run non-resistors in the 8+ heat range because they dont really have any resistor plugs that cold
Old Aug 20, 2010 | 11:55 AM
Retired Moderator
ehh to each his own..
I change mine every 2k miles anyways.. so these work for me.
Old Aug 20, 2010 | 11:59 AM
SPOOLINmatt's Avatar
bkr9eix is a resistor #9 plug 2669
Old Aug 20, 2010 | 02:01 PM
welfarepc's Avatar
NGK iridium's are also like $10 a pop!! not to mention you cant gap them... well... you can... but chances are you will *** your iridium tip
Old Aug 20, 2010 | 03:20 PM
AlexDphoto's Avatar
Ngk 1 step colder plugs at .025 gap
tuoniz
Aug 16, 2005 11:30 AM
mattEG
Sep 14, 2004 09:22 AM
import-tooner
Jun 28, 2004 04:38 PM
r7
Aug 26, 2003 05:18 AM
ALLMOTOR18
Sep 10, 2002 03:05 PM
