No spark/No fuel b18c1 swap
Old Aug 16, 2010 | 07:52 PM
nappyracing001's Avatar
Default No spark/No fuel b18c1 swap
I just did a b18c1 swap in my 99 ex im running a p72 ecu with the immobilizer removed. after repining the fuel pump relay from a16 to a 15 and also doing the crank sensor trick i finished everything i go to turn it over and have no fuel and no spark. before i get really pissed and buy hondata and find out that doesn't work either is there anything im overlooking or haven't done???????? what could i have possibly screwed up please help im desperate at this point
Old Aug 16, 2010 | 08:00 PM
Former User's Avatar
Default Re: No spark/No fuel b18c1 swap
Did you check fuse 44 and 13?
Is the G101 ground wire attached the thermostat housing clean and tight?
Old Aug 17, 2010 | 04:15 AM
I did check the fuses they are good i didn't check the ground yet once i get back to the shop tonight ill check it. There has to be something stupid and so obvious that i missed every plug is plugged every pin i needed to repin has been. Ive spent hours to make sure everything was perfect and i cant figure this **** out.
Old Aug 17, 2010 | 11:04 AM
anyone else wanna chime in??? help me think of things i could have missed that would cause no spark or fuel the pump don't prime or anything
Old Aug 17, 2010 | 04:05 PM
ok i checked the ground its perfect and i cleaned it extra good. both fuses are good. im stuck i dont know what to do please help!!!!!!!!!!!!!!!!!!!!!
Old Aug 17, 2010 | 04:22 PM
Now use a multimeter to test whether the main relay plug gets voltage from both of those fuses. Also check the main relay itself.
Old Aug 17, 2010 | 05:02 PM
ive got no power to the main relay and no power to #13 fuse for the fuel pump
Old Aug 17, 2010 | 06:30 PM
damn 90 views and noone else has ever had this same problem?
Old Aug 17, 2010 | 06:59 PM
i give up for tonight im phuked
Old Aug 17, 2010 | 07:01 PM
Fuse 13 sends voltage to the main relay on a Yel/Grn wire that pins to terminal 5 in the main relay connector. Or did you measure no voltage at the Yel/Grn wire that pins to terminal 4 (fuel pump) of the main relay connector?
Old Aug 18, 2010 | 09:47 AM
I got no juice to the fuse itself i took the fuse out and checked the terminals in the fuse box and nothing also any suggestions???
Old Aug 18, 2010 | 11:13 AM
Did you have the key in ON(II)?
Old Aug 18, 2010 | 01:52 PM
im honestly not positive ill me at the shop in a half hour ill check everything again
Old Aug 18, 2010 | 01:55 PM
Fuse 13 gets power via the ignition switch. If it's off, fuse 13 obviously will not have battery voltage.
By contrast, fuse 44 gets voltage from the hood fuse box so is hot at all times.
Old Aug 18, 2010 | 06:24 PM
i figured out what was causing no spark or fuel when i did the crank sensor trick i cut the wires in the wrong spark you must cut them before the splice not after. So huge screw up on me and also the fuel pump wire was not pushed in all the way so fixed that to. thank you for the help, but now i have another problem with my stock ecu it fired up but only for seconds, with my gsr ecu my cylinders filled up with fuel so what could that be now do i have to pull my splicing apart and check all that? it ran good with the stock ecu but only for seconds, with the gsr it did nothing
CraigG
Feb 9, 2009 04:56 PM
PrestonCRX
12
May 12, 2006 02:00 PM
temp
15
Jul 6, 2004 08:07 PM
2ndGenREX
Dec 3, 2003 07:11 PM
Yellow Dragon
Aug 26, 2001 04:38 PM
