Creaking when turning the wheel at low speed?
Old Aug 6, 2010 | 05:53 PM
ShinyNewPenny's Avatar
Default Creaking when turning the wheel at low speed?
Over the last month I've noticed that when I turn the wheel in either direction I can hear a loud creaking sound coming from the front of my car. I took a quick look under my car and I noticed that my passenger side outer axle boot is torn. Could the creaking just be from the torn boot/lack of grease on the axle joint?
I think my best option is to just replace the axle, but I don't wanna miss a different problem while I'm already under my car.
Old Aug 6, 2010 | 06:01 PM
Former User's Avatar
Default Re: Creaking when turning the wheel at low speed?
You do need to replace the axle with a torn boot, though I'm not sure that's the cause of the creaking.
Is the power steering (PS) fluid low in the reservoir? Is the PS pump belt loose?
Old Aug 7, 2010 | 07:09 AM
Markley02's Avatar
Do you have cheap coilovers? I have had them creak in the past
Old Aug 7, 2010 | 07:11 AM
300whpej's Avatar
check your steering rack. the passenger side boot on mine is torn and im sure it still creaks, i just ignore it
Jizzmaster Zero
12
Jun 16, 2006 02:42 PM
blackdelslo
Jan 23, 2005 07:27 PM
dxhatch92
Mar 18, 2004 03:15 PM
dxhatch92
Mar 18, 2004 02:02 PM
madman604
Sep 10, 2003 03:47 PM
