90 accord ecu problem
Old Aug 6, 2010 | 03:01 PM
scottypippen147's Avatar
Default 90 accord ecu problem
hello a few weeks ago i pulled out the engine on my accord because i planned to do a f23 vtec swap but i then found out that it was harder than i expected and not worth it at all so i dropped the stock f22 back in. once i plugged everything in and made sure everything was connected i went to start it and it only turns over. the dizzy doesn't get any power. and im pretty sure the ecu doesn't turn on because no check engine light comes on when i turn the key and the red LED on the ecu does not blink when i turn the key over. if anybody has an idea on what could cause this please let me know
Old Aug 6, 2010 | 03:30 PM
Accordin2me's Avatar
Default Re: 90 accord ecu problem
Check the pins on the connectors there easy to bend plugging them in with the faceplate on. Similer prob on my 93 at 'cept the "d4" light would flash, went to replace tcm after tryin everything else and found pin#4 bent.
Old Aug 6, 2010 | 03:40 PM
hmmm ok thanks ill give that a shot.you are talking about the connectors that plug into the harness on the engine right?
Old Aug 6, 2010 | 05:32 PM
GhostAccord's Avatar
Check your engine wire harness ground. It is the ground for the ECU. if it is disconnected, dirty or has a bad connection it won't start.
Old Aug 6, 2010 | 06:57 PM
How do i know what wire is the harness ground? And is it likely that removing the engine would have messed with the ground?
Old Aug 7, 2010 | 03:18 AM
You may have disconnected this particular ground in order to remove the engine. That is why it is a very common ground to miss when putting the engine back into the chassis.
It is known as G101 it is usually found bolted to the thermostat (90-93 Accords) and the end of the intake manifold plenum, on the drivers side. (94-97 Accords)
Old Aug 7, 2010 | 08:42 PM
you sir, are a GENIUS! hahaha thank you so much that fixed it. i never even looked at that and saw that it was ungrounded. i replaced the ecu and checked about every wire in the car and never checked that ground. wow i feel dumb but its all good and running now thank you =]
Old Aug 7, 2010 | 09:28 PM
endless22's Avatar
is this the ground you guys are talking about.. whats weird is my 93 lx dont have it . i checked all my ground from my ecu and there is only 2 or 3. cause i had a start problem one day and thought it was this ground but like i said it dont have it. but my problem was the main relay
Old Aug 8, 2010 | 12:00 PM
yes thats it. its funny because i dont even remember taking that ground off but i must have when i took the intake manifold off.
Old Aug 8, 2010 | 12:11 PM
endless22's Avatar
i wonder why my 93 lx dont have it but still starts and runs strong
Old Aug 8, 2010 | 12:24 PM
endless22's Avatar
i guess mine does have it but its just in a different location cause i followed all the grounds from my ecu and they are grounded under the fuse box under the hood
Old Aug 8, 2010 | 12:38 PM
hmm weird im not sure how much further that ground could go considering it is coming right off of the engine harness unless somebody spliced more wire onto it
dadlliboy
Jun 19, 2013 08:13 PM
gtownjoe
Jan 13, 2012 02:32 PM
shahmiezan
Jan 19, 2007 05:39 AM
tougetuned_ef
Jun 13, 2006 05:39 PM
zCivic
May 23, 2002 04:56 AM
