450hp+ how to get it????
what's up honda-tech i am new to this site as you can see lol, but this is the setup that i am currently going to be running
1st of all the motor is a gsr "b18c1"
:cp 9:1 pistons
: eagle h beam rods
that's really it for bottom end wise
:top end
: gsr head 5 angle valve job
: skunk 2 pro series valve springs
:skunk2 titanium retainers
:skunk2 pro series stainless valves - 0.5mm over
: edelbrock victor x manifold
:70mm throttle body-skunk2
:aem fuel rail
:aem fuel pressure regulator
:1,000cc "rc" injectors
:4bar map sensor
:arp head studs
:arp rod bolts
turbo parts:
:garrett gt3582r turbo
:tial wastegate 44mm
:smax intercooler hold's up to 650hp!
trans!
:bone stock gsr trans
:clutch, clutchmasters stage 4 6 puck "sprung"
flywheel: Act flywheel ultralite 7 or 8lbs havent decided yet
basically thats what i'm going to go with, the car will be tuned on chrome by clm racing, do you guy's think i'll be hitting the "10's" range with that setup! please let me know, if you have a need to tell me if i can replace 1 part i have on my list for another part that is better please do so! thank you!
:cp 9:1 pistons
: eagle h beam rods
:top end
:aem fuel rail
:4bar map sensor
:arp head studs
:arp rod bolts
turbo parts:
trans!
bumppp i hope i will be seeing high mid 10's with this setup, if you guys have a better turbo that you think i should go with please let me know i was looking at some precision 1's also!!!!! I would more than like it if you can tell me what extra parts i should throw on!!!!
http://lmgtfy.com/?q=450+hp+gsr+setups
now read. if you have any other very common questions, go to the faq first or do a search. this question is repeated to many times. /thread
KX,
Slow down! You have to give people time to read the thread. Bumping a thread like this is also a way to get you noticed by the Mods, and not in a good way.
You could also use a 750cc or 800cc injector with a slight bump in base fuel pressure.
Any E85 in your area?
Dude. Your setup is good. Put it together and have a well known tuner with a large customer base tune it. If you need anything, he....or she, should be able to let you know. And i see 450 on pump gas in your future. I didnt see a management system so im guessing jumper harness with obd1 ecu, chip, hondata?
KX,
isnt it great lol
I guess you dont understand my point. it took you 2 days of waiting on a forum board, and took me 2 sec to get to google and do a search. i could change some words around, and get more good results lol read up dude, you build it and tell us the results. every engine is different and you should know this.
thanks, i stumbled on it on another forum for repetitive questions. So now i use it. Coming back to read these made my day. I have a feeling people are going to be using this web site now lol
patience is a virtue you NEED to have with an fi car.
i am locking this because there is no technical merit in this thread, and usually threads like this get locked anyway because there is enough in this board to help you on your build.
you are encouraged to search for your answer especially when the topic has been covered before.
welcome to the board.
Boostedb20EH2
Aug 14, 2008 09:44 AM
Boostedb20EH2
Jul 25, 2008 08:43 AM
