Honda S2000 Honda S2000
I think I fixed the idle/clutch-in stumble!
Old Aug 5, 2010 | 05:58 PM
fivespeedintegra's Avatar
Default I think I fixed the idle/clutch-in stumble!
So after trying a map sensor wack, an ECU reset and a cleaning of the IAC valve (which was pretty dirty)...I still had the oh so common idle stumble/near stall issue.
My next effort was going to be replacing the MAP sensor. My car would do the whole nearly stall when clutching in or most often when you would move up slightly in 1st gear and then clutch back in (in traffic situations etc).
Well yesterday I replaced my old engine air filter with a Napa Gold air filter (made by Wix). The old filter was the original, having 31k on it. To be honest it was REALLY dirty, basically solid black all around.
In all my driving yesterday and today, I have had not 1 stumble. Fluke? Could be I guess, but it's never gone so long without a hiccup. I was even poking the throttle a little bit while at stop lights.....as this would normally cause the near stall before. Nothing. Idling perfect at 900-1000.
I'll update this thread if in fact it stumbles again, though in searching s2ki it seems as if a couple other people have changed the air filter and received the same fix!
*knock on wood!*
Old Aug 5, 2010 | 06:26 PM
bigmacnfries's Avatar
Default Re: I think I fixed the idle/clutch-in stumble!
a choked up air filter could do that i guess. nice work, and thanks for letting us know.
Old Aug 5, 2010 | 06:29 PM
No problem. The culprit in direct sunlight...looks better than it really is!
decode33
Honda CR-V & Element
Mar 21, 2011 05:36 PM
S2000Forsale
Honda S2000
May 30, 2006 09:55 AM
Seth94GSR
May 19, 2006 01:31 PM
hatchlessrex
May 12, 2005 06:13 PM
Gant
Sep 15, 2004 10:42 PM
