civic 92 hatch runs boggy after 6k??
stock d16z6 with 14b turbo
replaced:
water pump
rear main seal
6 puck clutch with sp pressure plate
450 injectors with resistor box
walboro 255
it bogs after 6k and takes a long time trying to reach 7400rpm..my friend monitor it by dataloggin it and the chart went down instead of up. it was running fine before the turbo..
what can cause this problem???
replaced:
water pump
rear main seal
walboro 255
i have seen something similar to that, after a certain rpm at full throttle, it would bogg out, he had a rubber intake on his turbo and it was suck the rubber intake closed blocking most the air to the turbo, just an idea......
slob20ef
Mar 15, 2012 07:31 AM
civic00hatch
10
Oct 21, 2008 01:05 PM
