d16z6 turbo problems
Old Apr 13, 2005 | 06:14 PM
alexsracing's Avatar
Default d16z6 turbo problems
running a d16z6 with a probe turbo , running a freinds map for a t3 turbo at 11.5-12.0 afr so its rich in boost does this cause the car to surge and stutter at high boost?, can being rich cause you to throw a rod?, but runs fine in 3 friends cars but with a little bigger turbos.
Old Apr 13, 2005 | 07:27 PM
93turbo16's Avatar
what are you asking? Did you gap your plugs?
Old Apr 13, 2005 | 08:00 PM
same program as me and 2 others , but he is using a significantly smaller turbo, can a rich environment cause a motor to stutter or blow?
Old Apr 13, 2005 | 08:09 PM
Evanmb44's Avatar
rich is better than lean....if you are running rich you are not going to detonate and blow your motor no
Old Apr 13, 2005 | 08:13 PM
how about extreamly rich
Old Apr 13, 2005 | 08:14 PM
Boltz's Avatar
Default Re: (Turboaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict &raquo;</TD></TR><TR><TD CLASS="quote">rich is better than lean....if you are running rich you are not going to detonate and blow your motor no</TD></TR></TABLE>
You can do damage from being over-rich
Bottom line is your trying to use a tune for one car on another with a different turbo, hence basemap not a tune.
Each individual setup is different
96hatchy
Jun 6, 2007 06:49 AM
ilovejdm
Mar 15, 2007 08:24 PM
lavo81
24
Aug 8, 2005 12:56 PM
h22turbolude
Dec 11, 2003 06:24 PM
