stripped Nrg hub bolts!!
I noticed that my NRG short hub was loose so I went to take it apart and tighten the main steering nut. then i stripped the 2 bolts from the hu assembly. I cant get it off now any suggestions?
If its a bolt, you can get a bolt gripper as well. YOu canT drill into bolts usually, but a hexoganal bolt top should be able to get gripped by a gripper.
So go to autozone, you will be just fine....just call for a ride obviously haha
Cheers!
