Intake.
So im getting an AEM CAI for my B16a and installing my old SRI into my friends 99 teg gs. Will this intake fit on his engine? I noticed on my car I have two inserts in the SRI, one for the o2 sensor I believe and the other tube that runs into the head. ( not sure what that does) Will this intake install in my friends ride?
Also I need to reset to ecu (I think) when I install it. So basically here is what I do to reset to ECU
-Unplug the battery
-let it sit for a bit
-start the car
-let it idle for 5-10 min w\o touching the gas
-turn the car off
-turn it back on
Please let me know if these are the correct steps to reset the ecu, I will do this after the intake is installed. and Thanks!
-Unplug the battery
-start the car
-turn the car off
-turn it back on
Reset the ECU by pulling the ECU fuse in the underhood fusebox. I believe its a 20A? But it says on the fuse box cover. Pull that for a couple of mins and your good to go.
When you restart the car DO NOT STEP ON THE GAS!
HTH!
Steve
HTH!
Steve
SubliminalMsger
Feb 23, 2007 03:58 AM
tsdenny
Jul 27, 2004 12:33 PM
