Skunk2 Pro Series Stage 1 vs Stock h22a cams
Honda-Tech Titanium Member
I was told that I should be changing my cams and that with the Skunk2 Stage 1 pro series cams I will be blowing the intake charge out the exhaust valves. Here's my set up on a t3/to4e 60-1 turbo...any advice on what cams I should be using. I'm aiming for 400whp.
HEAD
-1993 JDM H22a DOHC VTEC
-skunk2 pro series stage 1 cams
-skunk2 pro series cam gears
-skunk2 pro series valves
-skunk2 pro series titanium retainers
-skunk2 pro series valve springs
-skunk2 pro series intake manifold
-skunk2 pro series 68mm throttle body
-brand new jdm distributor
-custom painted valve cover w/ cut outs for cam gears
-3 angle valve job
-Cometic head gasket
-ARP main studs
-hondata intake manifold gasket
BLOCK
-jdm h22a block
-Mahle Gold Series 10:1 Compression/Stock Bore
-Eagle Forged H-Beam Rods
-ACL Main Bearings
-ACL Rod Bearings
-ARP Rod Bolts
-Balanced and Micro Polished Crank
-Kaizen Speed Balance Shaft Eliminator Kit
-New OEM Water Pump
-New OEM Timing Belt
-H23 Manual Tensioner Conversion
-ARP Head Studs
-Moroso Oil Pan
-Moroso Oil Pick-Up
mozzandherb is online now Report Post Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
HEAD
-3 angle valve job
-ARP main studs
BLOCK
-jdm h22a block
-ACL Main Bearings
-ACL Rod Bearings
-ARP Rod Bolts
-New OEM Water Pump
-ARP Head Studs
-Moroso Oil Pan
-Moroso Oil Pick-Up
Why spend the big money on cams? ive made (and so have tons of other people) over 600whp on stock cams... your not going to gain much at that power level... why not save the 500 bucks and just turn the boost up a few PSI?
My head was COMPLETLY stock, only revving to 8k RPM on 29psi with a 35R to make the numbers in my sig.... that was on pump gas and meth, ditch the ARP main studs as well unless the main line has been check out already with them in...
For only 400whp... stock cams will work just fine. We've tuned tons of H's on stock cams making much more then 400whp. Invest that money into a properly designed turbo manifold as the log styles will cause exhaust reversion on the H's.
I have a custom tubular manifold. The problem is these cams came with the motor that I bought, so for now I am keeping them in there because the car is getting tuned this week, my only concern was if the cams were going to be a real problem
if you think about it, does it really make sense what you are asking? Why would SKUNK2 spend a ton of money on R&D to make cams that are so big that the over lap like that? Sounds like some one with a V8 is trying to talk about something they know nothing about. SKUNK2 makes bigger cams then that. You should be fine, and if you have ANY doughts, call or email SKUNK2 they have been great about answering questions i have had in the past.
With the pro1's on turbo a very good flowing turbo manifold will be needed a log/restrictive turbo manifold will cause issues with such a cam.
Peckrwood
Sep 10, 2012 09:29 AM
civic b16b
Mar 20, 2007 10:56 PM
