crankcase pressure on decelleration??
Old Sep 16, 2002 | 11:15 AM
Shft@9GSR's Avatar
Default crankcase pressure on decelleration??
my problem is that well first of all, I think my real main seal is blown now. The reason is that I think that when decellerating, i smell what seems to be burning oil. Not out the exhuast but from the engine bay. It is leaking out what seems to be the oil pan or the rear main seal. Can't really see.
Motor is a LS/VTEC. if that matters
Question?? is there a way to releive excess pressure in the crankcase upon decelleration? I am currently using the stock PCV setup. I'm not sucking up oil into the TB or anything, just spitting oil out the oil pan gasket or rear main seal onto the exhuast upon decelleration. If I put the car in neutral and let the car idle while decellerating, I don't have that problem. Only when motor is coming down in revs. (decellerating using the engine as brakes)
I will fix the leaky seal problem but don't want it to be a reoccuring problem.
Old Sep 16, 2002 | 11:20 AM
Spade's Avatar
Default Re: crankcase pressure on decelleration?? (Shft@9GSR)
THe PCV could be bad.....that is the easiest thing to replace right now....try that first.
Old Sep 16, 2002 | 11:25 AM
Shft@9GSR's Avatar
Default Re: crankcase pressure on decelleration?? (Spade)
it's new. Like 2k miles with it. and it's been that way for a while.
thanks for the reply though.
Old Sep 16, 2002 | 12:31 PM
X2BOARD's Avatar
Really sounds like the PCV valve... but if it's already new.... ummm...... did you check all of the PCV system's hoses for holes/leaks ?
Old Sep 17, 2002 | 11:14 AM
Shft@9GSR's Avatar
Default Re: crankcase pressure on decelleration?? (X2BOARD)
I checked all hose and everything looks good. car idles fine (like there is no vacuum leak). I'll try getting another PCV and see what happens.
Thanks for the help.
Old Sep 17, 2002 | 03:58 PM
tonyxcom's Avatar
Do you have the breather hose attached on your valve cover? That is another place you can releive preassure.
88 EF Hatch
15
Jun 10, 2009 07:36 PM
88 EF Hatch
Jun 7, 2009 10:32 PM
Beau Gotti
Feb 24, 2008 12:11 PM
95LXDRIVER
Dec 1, 2005 10:35 AM
