Anyone know where to get a tee with BSPT and two 1/8 NPT outlets?
Old Sep 16, 2002 | 10:56 AM
canuck-mx6's Avatar
Default Anyone know where to get a tee with BSPT and two 1/8 NPT outlets?
I am planning on removing the oilpressure sender on the back of the block so that I can tee it off and run an oil temperature gauge. I know that the thead is British Standard pipe thread, so that is the tee that I need. One of the outlets needs to be 1/8 national pipe thread as that is what my autometer gauge uses.
Anyone know of a Tee that has BSPT one the inlet, and NPT on one of the outlets and BSPT on one of the outlets so that I can reuse the Oil pressure sender?
If there is an easier way to do this, please let me know
Old Sep 16, 2002 | 11:25 AM
Rocket's Avatar
Default Re: Anyone know where to get a tee with BSPT and two 1/8 NPT outlets? (canuck-mx6)
There is a Apexi oil filter sandwhich that has three taps. This sounds like the way to go since the tees are notorious for breaking.
Old Sep 16, 2002 | 12:01 PM
sgT's Avatar
sgT
1/8" NPT is close enough to work.
Why would you want to reuse the stock sender? Its completely useless.
Old Sep 16, 2002 | 12:53 PM
canuck-mx6's Avatar
Default Re: Anyone know where to get a tee with BSPT and two 1/8 NPT outlets? (sgT)
Because I do not want to run an oil pressure gauge, and the OEM sender is better than nothing.
Anyway, after laborious searching, I found this
I think that I will use this arrangement
Old Sep 16, 2002 | 01:16 PM
sieger's Avatar
What a coincidence. I went by the same picture and just got my parts today.
http://www.pegasusautoracing.com
AM3226 12' Nylon Tubing Kit
1073 1/8 BSP M&F Pressure Adapters
3212 Female Tee fitting: 1/8 NPT Brass
The only thing I need now is a 1/8NPT nipple to connect the female end of the tube kit to the female end of the BSP adapater in the block. I didn't realize that the tube kit had one female and one male instead of the two males i needed. The only reason I got the 12' instead of the 6' was because it 2 bucks more and they had it ready to ship, i would have had to wait for the 6'. Hope this helps ya.
Old Sep 16, 2002 | 01:48 PM
rolow's Avatar
Default Re: Anyone know where to get a tee with BSPT and two 1/8 NPT outlets? (Rocket)
Rocket
Do you have any pics or a link?
Can I run the feed line for my b20 vtec with it?
Old Sep 16, 2002 | 01:57 PM
Rocket's Avatar
Default Re: Anyone know where to get a tee with BSPT and two 1/8 NPT outlets? (rolow)
I might have a pic soon. A customer of mine told me about it and a light bulb went off in my head saying that's the way to go.
Old Sep 16, 2002 | 02:01 PM
rolow's Avatar
If you wouldn't mined posting it or email it to me when you get it that would be great.
Ant idea on a price?
Mike
Old Sep 16, 2002 | 02:09 PM
Rocket's Avatar
I think its like $50.
fryman
Aug 26, 2009 10:42 PM
nicko360
Mar 14, 2007 02:52 PM
n0pinitr0us
21
Apr 10, 2005 08:55 PM
crx1856
Aug 8, 2003 02:11 PM
dualknuttz1
Apr 28, 2003 02:57 PM
