how to tell the difference on oil feed lines.
how do i kno if i have a -3an or -4an oil feed line? I have a oil feed line i thought was a -3an and a buddy came over and said it was a -4an line. how do i kno which one it really is? need to get a restrictor so i need to kno which line i have. thanks!
i guess i measure the O.D. then. i measured it couple times again and got 0.328" to 0.344"..... it does not match any of the numbers thats listed in that graph.
Thats because the chart is referring to the inside diameter of the hose. You will have to cut it open if you want to know what size it is or some how figure out how thick the tube wall is.
the chart is telling you to measure the diameter of the fitting on the end of the line, so you dont need to cut anything. most likely you have female threads on the end of the line so measure the inside of them
At the hardware store the fittings will be called JIC and not AN. They are the same type of fitting though. Here's how to convert from one to the other.
-3 AN = 3/16" JIC
-4 AN = 1/4" JIC
-6 AN = 3/8" JIC
-8 AN = 1/2" JIC
-10 AN = 5/8" JIC
-12 AN = 3/4" JIC
-16 AN = 1" JIC
Take the line with you to your local hardware store, and try screwing it to different size fittings to see what size you have.
-3 AN = 3/16" JIC
-4 AN = 1/4" JIC
-6 AN = 3/8" JIC
-8 AN = 1/2" JIC
-10 AN = 5/8" JIC
-12 AN = 3/4" JIC
-16 AN = 1" JIC
-3 AN = 3/16" JIC
-4 AN = 1/4" JIC
-6 AN = 3/8" JIC
-8 AN = 1/2" JIC
-10 AN = 5/8" JIC
-12 AN = 3/4" JIC
-16 AN = 1" JIC
How much oil is coming out of the oil feed line and how fast? and if my return is the same size as t
seeeya04
Dec 7, 2005 01:18 PM
