turbo si with fog lights.
Old Jul 27, 2010 | 11:56 PM
young geezer's Avatar
Default turbo si with fog lights.
ok so who in here has civic si front end with oem fog lights. my pipping seems to get in the way. soi want o know how you guys got around that. thanks.
Old Jul 28, 2010 | 12:47 AM
numba1stunna201's Avatar
Default Re: turbo si with fog lights.
i wasnt able to figure it out either, idk if its possible without looking like garbage
Old Jul 28, 2010 | 12:50 AM
DCRB's Avatar
perhaps you can flip the intercooler upside down? so the pipes run through the top of the bumper?
Old Jul 28, 2010 | 01:31 AM
chewyv's Avatar
pm4nudes
take the lights out
Old Jul 28, 2010 | 02:05 AM
Nichelson_Performance's Avatar
a good buddy of mine had a 00 hatch ls turbo and he kept his foglights....i know his intercooler piping was custom built by h-t member RC000e and i think they inverted the intercooler also
it was one of the cleanest setups i've ever seen and was done using only 5 silicone coupler i believe....his honda-tech username is rickcrx if you wanna check out some pictures he has, i'm not sure if he shows under the hood but if you do some searching i know he posted up pictures before
Old Jul 28, 2010 | 08:35 AM
apexi_rsx's Avatar
get a back door intercooler would probably be your best bet. so the piping is run through the back not to the sides like most intercoolers are
Old Jul 29, 2010 | 11:08 AM
BuiltforSin's Avatar
Not possible to keep the fogs unless you do something as mentioned above.
Old Jul 29, 2010 | 11:16 AM
Bwill9886's Avatar
My friends 00 EX has never had an issue with the piping and intercooler. This is with a new Mishimoto IC (around 27x11x3) that we just put on a few weeks ago. It fit with the old, beat up greddy one as well (which was basically the same size).
The trick seemed to be keeping the IC as low as you can while still fitting in the bumper cover, and having the bottom as close to the core support as you can manage. This was not hard to do btw and fits just fine. I could see clearance problems if your charge piping was bigger than 2.5" though.
I can try to elaborate further if necessary.
Old Jul 30, 2010 | 08:48 AM
apexi_rsx's Avatar
this could work but if you cars lowered i would not recomend this as this is just killing ur ground clearance and would suck if u hit your piping
Old Jul 30, 2010 | 09:11 AM
jo_nathon's Avatar
upside down would probably be your easiest fix
then the piping will run right over your fogs
i just walked outside and looked at my car and i'm sure it would work
Old Jul 30, 2010 | 09:18 AM
kaiba's Avatar
Old Jul 30, 2010 | 10:52 AM
the EG looks like a badass ride, but the fitment on the whole front end is extremely poor
the EK's though were done very nice, i'm really diggin the 96-98 all except for the hood
Old Jul 30, 2010 | 06:29 PM
Bwill9886's Avatar
This DOES work, and on a lowered EJ8. No clearance issues whatsoever. Only time I have seen trouble was when I had the bottom of the IC initially bolted up farther out. This caused the piping to hit the foglight brackets.
Originally Posted by kaiba
My friends Civic is lowered AT LEAST as low as the two shown here by kaiba (more like the first pic). If you hit in the front, you'll hit the lip/bumper cover before the piping or IC.
AnclyT
Feb 8, 2009 08:02 PM
JDMFantasy2k
Aug 3, 2008 09:43 AM
GreenD16Y8
Apr 12, 2006 06:31 PM
phantom grey eg
Jan 26, 2005 07:15 PM
Soon_2b_evil
Feb 4, 2004 07:28 AM
