When you rebuild a motor do you have to use stop leak to stop the water pump leaking
Old Jul 27, 2010 | 06:42 PM
danmej1's Avatar
Icon2 When you rebuild a motor do you have to use stop leak to stop the water pump leaking
I need to know this please and stop deleting all my threads, my water pump is leaking and wondering if using stop leak is a good idea to stop it from leaking because my freind told me when he rebuilt his ls/vtec low compression build he had the same problem with the water pump and his leaked also and he used stop leak and it stoped leaking even though it was a fresh rebuild with no miles too.
Old Jul 27, 2010 | 06:49 PM
danmej1's Avatar
Default Re: When you rebuild a motor do you have to use stop leak to stop the water pump leak
bump I need help please thanks
Old Jul 27, 2010 | 07:02 PM
ZacCarter's Avatar
DUDE YOUR THREAD WASN'T EVEN ON THE SECOND PAGE!!!!!!!!! There was no reason to bump it.
To answer your question we are gonna need a little more info.
How many miles are on the pump? When was the last time you did the water pump/ timing belt service? What kind of shape is the timing belt in? Is it leaking from the pulley or the gasket?
Old Jul 27, 2010 | 09:03 PM
wreckeddc4's Avatar
Stop leak is terrible for your motor and should not be used. When your motor was rebuilt was the water pump replaced with a new one? If so it could be defective, especially if its aftermarket from like auto zone or something like that. Also theres a chance it was installed incorrectly, your supposed to use a small amount of sealant around the pump mating surface when you bolt it on. Also the bolts must be torqued to the right rating. Another thing is the o rings on the tube that connect the pump to the thermostat housing should be replaced whenever you replace a waterpump. When installing these o rings they must be lightly lubed to ensure they go in and seat properly, because if not they tear or fold against itself and dont seal. Hope this helps
Old Jul 27, 2010 | 09:21 PM
itslogz's Avatar
Probably that part i bolded. I just went through the same ****, took me 3 trys of taking the IM off and redoing it before I realized that was all i had to do to stop it.
If its coming from where the pipe meets the block on the timing belt side, thats definitely it, and its a bitch lol
Old Jul 28, 2010 | 01:00 AM
speedtec11s's Avatar
compression has nothing to do with your water pump leaking.
If your rebuilding the motor...change the water pump...spend the$75 bucks and save the piece of mind. It will come with a new seal,...just put a light layer of honda bond on it and u will be golden.
Old Jul 28, 2010 | 04:13 AM
88Hatchy's Avatar
This shouldn't be necessary.
Old Jul 28, 2010 | 04:35 AM
kyden's Avatar
i agree, its a captured o-ring.
Old Jul 28, 2010 | 08:21 AM
newtron63h's Avatar
just want to make sure you saw it and understand. stop leak is for EMERGENCIES ONLY. think about it, how does it know where the leak is? it doesnt, which means that its going to stop "leaks" anywhere it can in the cooling system. so any small opening, or corner, or crevice, or hole, or passage has the chance of getting clogged. no good, stay away from it.
anyone who uses stop leak as a first fix, doesnt know anything about cars and shouldnt be trying to fix anything.
Old Jul 28, 2010 | 04:15 PM
danmej1's Avatar
so I need to get new rings for where the coolant metal hose connects to the water pump and don't use stop leak.
Old Jul 28, 2010 | 04:17 PM
danmej1's Avatar
It is leaking from the gasket timing belt new and it is starting to leak alot now only when motor is on
Old Jul 28, 2010 | 04:39 PM
fv8s's Avatar
did you use RTV? or any type of sealer. your question is so vauge. there is a rubber gasket on the pump itself obvioulsy and the rubber ring on your water pipe. if you have both of those on and used RTV it should not leak
Old Jul 28, 2010 | 09:49 PM
danmej1's Avatar
I did also I was wondering why my timing belt won't stay tensioned does anybody know why do I need a new tensioner and also I have a spare one from my other gsr block should I just use that one?
Mr_Moos
Jun 24, 2007 10:04 PM
92civicfreak
Jun 1, 2007 02:26 PM
turq93t
10
May 16, 2005 06:00 PM
Mrob91GS
Mar 26, 2005 08:25 AM
pnthr30
Oct 28, 2003 08:38 AM
