CEL...need help in what to do next.
Old Jul 26, 2010 | 05:16 PM
Bigrome34's Avatar
Default CEL...need help in what to do next.
I have a 99 Si and I have a CEL on. I started out with 4 and now I am down to this last one. The code on the scanner is P0172 fuel system too rich... I have already changed the fuel filter to no avail. What could be another solution?
Old Jul 26, 2010 | 05:35 PM
SeanK325's Avatar
Default Re: CEL...need help in what to do next.
from obd-codes.com
Possible solutions include:
- Inspect all vacuum and PCV hoses, replace if necessary
- Clean the MAF sensor. Consult your service manual for it's location if you need help.
- Inspect fuel lines for cracks, leaks, or pinches
- Check the fuel pressure at the fuel rail
- Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
- Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
Old Jul 26, 2010 | 07:00 PM
Bigrome34's Avatar
would that be a maf sensor or a map sensor???
Old Jul 26, 2010 | 07:10 PM
Sr420Det's Avatar
Your honda uses a map sensor help tell how much air is entering the motor. How do your plugs look?
Old Jul 26, 2010 | 07:20 PM
Bigrome34's Avatar
spark plugs???
Old Jul 27, 2010 | 06:54 AM
Sr420Det's Avatar
yeah the spark plugs, do they look overly rich to you?
Old Jul 27, 2010 | 08:43 AM
Former User's Avatar
Measure the fuel pressure and check whether the fuel pressure regulator is working.
Also check for a stuck open fuel injector.
Old Jul 27, 2010 | 09:13 AM
Bigrome34's Avatar
spark plugs have a little bit of oil on them
Old Jul 27, 2010 | 09:15 AM
Bigrome34's Avatar
how do i check fuel pressure and wether the FPR is working or not? how would i check for an open fuel injector?
Old Jul 27, 2010 | 09:18 AM
honda-992's Avatar
yea if i were you i would check all vacuum hoses because it sounds like a vacuum leak..or a small crack before the first o2 sensor..on my 97 civic i had a tiny exhaust crack before the o2 sensor and it threw a cel for fuel mixture
Old Jul 27, 2010 | 09:38 AM
See diagram and check for fuel flooded cylinders.
Old Jul 27, 2010 | 12:58 PM
Bigrome34's Avatar
well i know for sure that my headers have a leak in them...they are scraped on the bottom side...could that be the problem?
ron, i will try the test out and see if that works
Old Jul 27, 2010 | 01:01 PM
An exhaust leak near or upstream of the primary O2 sensor would make the engine run rich.
HITECVTEC
Aug 16, 2018 09:08 PM
weirdone86
Sep 14, 2006 07:35 AM
iowarex72
May 27, 2004 02:22 PM
CIVIX
Oct 29, 2002 03:10 AM
