CEL...need help in what to do next.
I have a 99 Si and I have a CEL on. I started out with 4 and now I am down to this last one. The code on the scanner is P0172 fuel system too rich... I have already changed the fuel filter to no avail. What could be another solution?
Re: CEL...need help in what to do next.
from obd-codes.com
Possible solutions include:
- Inspect all vacuum and PCV hoses, replace if necessary
- Clean the MAF sensor. Consult your service manual for it's location if you need help.
- Inspect fuel lines for cracks, leaks, or pinches
- Check the fuel pressure at the fuel rail
- Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
- Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
yea if i were you i would check all vacuum hoses because it sounds like a vacuum leak..or a small crack before the first o2 sensor..on my 97 civic i had a tiny exhaust crack before the o2 sensor and it threw a cel for fuel mixture
well i know for sure that my headers have a leak in them...they are scraped on the bottom side...could that be the problem?
ron, i will try the test out and see if that works
HITECVTEC
08-16-2018 09:08 PM
