Ls/vtec fuel issues
Old Jul 26, 2010 | 09:53 AM
Da4yoA$$'s Avatar
Default Ls/vtec fuel issues
trying to figure out a few things for a buddy of mine and his ls/vtec setup...Car runs great until you hit WOt...then it seems to fall on its face....Has walboro 255 pump and stock injectors at 55psi using a afpr....Is it possible that the duty cycle of the injectors is at 100% causing it to bogg out from not getting enough fuel...Ive read that 310cc injectors are the minimum correct....it will roll out as long as your not at WOT...Any help would be appreciated...Thanks in advance...
thanhzz
Aug 28, 2011 10:10 PM
JDMh0ndaDC2
Nov 24, 2007 07:58 PM
sn34k
Oct 7, 2004 06:57 AM
HarryB
Jul 4, 2002 11:58 AM
