LS/V???'S, PLEASE HELP...
Old Jul 25, 2010 | 03:11 PM
ej1.8's Avatar
Default LS/V???'S, PLEASE HELP...
ok, first off i'm not very familiar with the site and don't visit much, but i was recommended by another user who always finds the H-Tech very useful. i'm running an ls/v with a crower'd out head. cams are 63402-2, and i recently installed a set of blox cam gears (BXPT 10100). my timing's dead on, cam gears are zeroed and the car fires up on first crank. the problem i'm having is that i'm hearing a kinda loud knock in the head, now i'm guessing my question is should my cam gears be adjusted to correct this prob, and if so by what degree or so?????? please help. ( before replacing the oem cam gears to the blox, their were absolutely no knocking). call or txt if u have possible solutions please, car's my daily and need this prob fix asap. 678-895-6669
Old Jul 25, 2010 | 03:17 PM
kicken90crxsi's Avatar
Default Re: LS/V???'S, PLEASE HELP...
did u set ur valve adjustment?
Old Jul 25, 2010 | 03:23 PM
ej1.8's Avatar
no i didn't, i suggested and asked a friend of mine who tuned for me in the past, but he suggested re-timing and go from their. could it be a possible valve lash ur suggestig?
Old Jul 25, 2010 | 03:34 PM
EdSales's Avatar
You should have set your valve adjustment before you started the car.
Old Jul 25, 2010 | 03:48 PM
ej1.8's Avatar
well i didn't think i'd need to do a another valve adjustment, i recently had it done several weeks ago and all was good. as well i didn't remove the cams or anything, just replaced the gears, but i guess it's a start so i'll give it a shot.
Old Jul 25, 2010 | 05:27 PM
q16racer's Avatar
cam gears torqued?
timing belt tight?
________
Mustang Ssp
Old Jul 25, 2010 | 06:16 PM
MOTION_80's Avatar
does your lma are good ?
Old Jul 25, 2010 | 10:54 PM
ej1.8's Avatar
cam gears was shot with an impact so i'm assuming they're pretty damn tight, and the timing belt is good n tight.
Originally Posted by q16racer
cam gears torqued?
timing belt tight?
Old Jul 25, 2010 | 10:59 PM
ej1.8's Avatar
i'm honestly not too certain, and was sure how to check em. but i was told to puch down on them n see whether or not they stick. if so, then that could possibly be the prob? i'm gonna assume that valvle adjustment needs to be done; however, i wont be doing it, i'ma have an expert get on that one n get bk to the tech with my results. any other suggestions i'd greatly appreciate. thanks much everyone, i will let u all know wats the outcome.
Old Jul 26, 2010 | 04:45 AM
kyden's Avatar
uh.. why would you use an impact to put on cam gears?
Old Jul 26, 2010 | 05:12 AM
ej1.8's Avatar
idk man, guess it was a silly thing to do, and also probably cause they were so tight at first. i wasnt able to break it with all my might, and didn't think it would prove so detrimental using the impact.
Old Jul 31, 2010 | 11:54 PM
ej1.8's Avatar
adjusted valves .006 in/.007 exh same ****, replaced cam gear back to factory n the problem went away.WTF????????? they were BNIB, has anyone had any relating issues with blox cam gears (bxpt 10100)?
Old Aug 1, 2010 | 07:08 AM
95skunkedgsr's Avatar
hmmm was the adjustable cam gear bolts tight ?? it sceems like they might have been lose and the noise you where hearing was the cam gear sliding around on the that adjustable part take a look at the front and back of the cam gears to see if there is scratched metal or anything from them sliding around
Old Aug 1, 2010 | 08:27 PM
ej1.8's Avatar
no, they were absolutely tight because i zeroed n tightened them prior putting them on.
MattD@Stoptech
Apr 9, 2004 07:26 AM
91integraLSVTEC
Aug 22, 2003 08:54 PM
1bad-eg
Dec 9, 2002 04:46 AM
Austin
Nov 18, 2002 01:20 PM
LshatchTurbo
Aug 18, 2002 11:53 PM
