instrument cluster help quick
Old Jul 24, 2010 | 01:01 AM
Blu3 1ightning's Avatar
Default instrument cluster help quick
i really need help i looked in my manual but could find what i need. i must have burned out a relay or fuse because now my speed tach and heat do not work on my cluster swap or my stock cluster but all the signals work and lights still work on my 04 civic cluster but on my stock one cel light and battery light dont work now.is this a relay or a fuse i looked under the hood at fuses and looked under the dash but couldnt find anything
Old Jul 24, 2010 | 03:08 PM
Default Re: instrument cluster help quick
no one wants to help?
Old Jul 24, 2010 | 03:29 PM
tomd15's Avatar
wood if could
Old Jul 27, 2010 | 04:24 PM
any one else want to try to help? the best thing i can think is that i either fryed all the sensors like the vss heat sensor fuel and rpm but the seams unlikely. is there some sort of cpu or something that controls all this.
Old Jul 27, 2010 | 05:46 PM
lazlong's Avatar
1st-This is the 92-00 forum, not the 01-05 forum.
2nd- ALWAYS disconnect the batt- cable before touching wires. if your working near SRS wires you need to disconnect the batt+ cable too and wait at least 3 minutes so you don't blow your airbags.
3rd- You probably blew your multiplex control unit (MCU). It's in the under-dash fuse box. Check fuses #'s 2, 3, and 9 in under-hood fuse/relay box and #10 in the under-dash fuse box with a test light or DMM (multi-meter). Don't just eyeball it.
EGed up from the seat up
Mar 4, 2009 04:13 PM
mugencivic94
Aug 17, 2007 09:54 AM
unknown0001
Aug 9, 2006 02:03 PM
Slvr_CRX
10
Jul 12, 2005 12:06 PM
Civicvtihatch
Sep 16, 2004 10:28 AM
