ROD bearing NOISE
Old Sep 15, 2002 | 08:07 PM
ANB Clothing Co's Avatar
Default ROD bearing NOISE
hey, was just wondering what noise the rod bearings make....ive got a ticking coming from my motor, but it doesnt happen constantly, its stops every now and then....was wondering what it was...
Old Sep 15, 2002 | 10:30 PM
salbaje's Avatar
Default Re: ROD bearing NOISE (KingKong)
your valves might need adjustment
Old Sep 15, 2002 | 10:52 PM
earl's Avatar
Not your rods making noise. Very light intermittant ticking can be injectors. Valve adj should be more constant ticking noise.
Old Sep 15, 2002 | 11:12 PM
Default Re: ROD bearing NOISE (earl)
i dont think its the injectors cause i didnt notice the pinging until i over revved from a miss-shift.....im thinkin i just need a valve adjustment...but dont quote me on the miss shift caused the pinging, it just so happened i started noticing the pinging after that happened....im not sure if it was pinging before...i think it was...just not as bad...
Old Sep 16, 2002 | 07:41 AM
earl's Avatar
So it's now pinging and not ticking? Do valve adj and check for broken springs or retainers. Do compression check. Check tension on timing belt. Look at everything.
If you need help, you got to give helpful info...like noise came on after missed shift
Old Sep 16, 2002 | 07:43 AM
non-VTEC's Avatar
if it was a bad rod bearing you would hear some pretty loud knocking...you probably need a valve adjustment. set the clearences to the minium spec and they should be fine..........
Old Sep 16, 2002 | 11:38 AM
what is the difference between a ping and a tick? i never can tell....
Old Sep 16, 2002 | 11:51 AM
earl's Avatar
22.5 db's
Old Sep 16, 2002 | 11:12 PM
db's as in decibals? so i need a decibal meter to tell if its a ticking or a pinging? that sounds kinda rediculous...
Old Sep 16, 2002 | 11:56 PM
Sonny's Avatar
LOL...nice, Earl!
King Kong: Pinging is a common name for detonation. It's likely that your valves need some work if this problem arose after a mis-shift.
Sonny
[Modified by Sonny, 12:57 AM 9/17/2002]
Old Sep 17, 2002 | 02:22 AM
MikeSarr_GSR's Avatar
Default Re: ROD bearing NOISE (Sonny)
oh bubba. let the car get completely cold and check the vavle clearances with the feelers and go every 90 and write down what they are at. do .006 or .007
on intake and .008 on exhaust. chances are you might have had some valve contact on that missed shift. if the valve adjustment doesnt clear things up
missed shifts have claimed exhaust valves a few times in my car...
this is the way we bend our valves
bend our valves
bend our valves...
sorry man
Old Sep 17, 2002 | 05:30 AM
Grimm's Avatar
Default Re: ROD bearing NOISE (MikeSarr_GSR)
Get it checked out check everything I blew a rod bearing and junked my engine. for me it sounded like a ping thru out 3k-4k rpms then the ping was more constant. i thought it was just my oilpan knocking or, heat sheilds knocking somewhere. needless to say it wasn't and may now i'm the proud owner of a b18c1....
Old Sep 17, 2002 | 08:29 AM
earl's Avatar
OK..j/k
Old Sep 17, 2002 | 08:39 PM
I just broke a B18C1 unfortunately... slag is available one main and one rod bearing were wiped. the rest of the block is solid.
Old Sep 17, 2002 | 09:25 PM
shermanyang's Avatar
i would also like to know what it would sound like if your rod bearings were making noise.
Old Sep 17, 2002 | 09:56 PM
Rocket's Avatar
Default Re: ROD bearing NOISE (shermanyang)
It almost sounds like a an exhaust leak at the header.
Old Sep 22, 2002 | 10:11 PM
Default Re: ROD bearing NOISE (Rocket)
it goes...
naka naka naka naka
at idle
and when you sap the throttle...
it goes...
nakanakanakakankanakanaknakaKNOCKONAKNOCKAnakanaka
then back to the sound at idle:
same as above.
there is a place in the RPM band where it may become muted, but
dont fool yourself. the longer this goes, you can wipe your crank
and have to start over with a new one.... bad bad bad monkey
it sounds like someone let a large marble loose in your motor
Old Sep 22, 2002 | 10:20 PM
FLIPboi's Avatar
it dose sound like that for real , well kinnda mine did it though 3000 to 4000 rpm and it sounded like lil kids in my motor with a hammer , of course i slung a rod bearing and bent my crank shaft and lock it in the motor in my civic d16 hatch, but now im happy with my civic b18 hybrid hatch ,
Old Sep 23, 2002 | 06:12 AM
Crazydave's Avatar
Default Re: ROD bearing NOISE (FLIPboi)
I dunno.. when I spun a main rod bearing it sounded like my valves
then when I drained my oil.. I found chunks of metal..
drain your oil look for metal...
Old Sep 23, 2002 | 08:52 AM
Ricky Rojales's Avatar
MikeSarr_GSR, your so onomatopoetic
Old Sep 23, 2002 | 11:24 AM
Default Re: ROD bearing NOISE (P)
thats a great euphamism
anywhoo, if you had bent valves you would not have bearing
material in your oil pan. thats what bearings look like when they
reach the service limit. they "spin" or shave off
whiteboy-dc4
Feb 13, 2009 01:31 PM
Spody02
11
Jan 8, 2009 07:02 PM
user 4747283
Feb 18, 2007 07:21 PM
Touge Tuning
Oct 15, 2006 11:04 AM
mikeunreal2
Apr 21, 2006 10:15 PM
