What Prop valve to use if going non-abs on an ITR
Old Jul 14, 2010 | 09:06 PM
weavertime1's Avatar
Default What Prop valve to use if going non-abs on an ITR
I recently picked up a '00 ITR shell that was stripped to almost nothing. Anyway, I am elminating the abs wiring and lines, and I need to alsoknow what prop valve ot use if I plan to run the normal 5 lug suspension/brake setup. Any hep would be greatly appreciated. Thanks!
Old Jul 14, 2010 | 09:42 PM
goldpearleg6's Avatar
Default Re: What Prop valve to use if going non-abs on an ITR
would suggest a 40/40 Prop valve
Old Jul 14, 2010 | 10:01 PM
ACTION JACTION's Avatar
I did the same, check your pm.
Old Jul 15, 2010 | 04:12 AM
Ok, but out of whatcar...IDK if the old 40/40 props work, but I know that the civic Si has one for non-abs, that looks much like the abs one the itr has in it. thanks!
Old Jul 15, 2010 | 08:08 AM
all 40/40's are the same use any one you want
Old Jul 15, 2010 | 10:08 AM
94rs-turbo's Avatar
you can use 99-00 si or 98 integra RS
Old Jul 15, 2010 | 05:34 PM
That's what I was thinking...I just don't want to bend my lines to run the older 40/40 prop. Thank you for your help!
no1else
Suspension & Brakes
Apr 5, 2012 11:17 PM
01-0720
Jan 22, 2012 09:25 AM
Ej8_KiD
Suspension & Brakes
Apr 2, 2011 07:06 PM
5lug hatch
Feb 4, 2009 08:44 AM
Bangers
Feb 14, 2008 07:05 PM
