b20 block: worth buying?
Old Jul 14, 2010 | 03:32 PM
flipldls's Avatar
Default b20 block: worth buying?
debating if i should buy this b20 short block and rebuilding it, but don't know if its worth it. The guy had it boosted and one of the pistons melted and scuffed up one of the cylinder walls. So from you perspective is it worth buying and rebuilding.......(links of Pics of block below)
Old Jul 14, 2010 | 03:34 PM
Wayeng's Avatar
Default Re: b20 block: worth buying?
worth about 50bucks
Old Jul 14, 2010 | 03:50 PM
State.of.Prime's Avatar
Cast pistons in F/I application = FAIL
Old Jul 14, 2010 | 04:10 PM
DDTECH's Avatar
Do you wanna make power??
Buy the block, send it off and have it cleaned and hottanked, it'll look brand new compared to that pic..
Old Jul 14, 2010 | 04:11 PM
GranDaddyPurp's Avatar
no not worth it. you should just find one in good condition already and build upon it instead of trying to fix that one.
Old Jul 14, 2010 | 04:14 PM
DDTECH's Avatar
What?
That block is a stock 84mm, bore it out to 84.5mm and be done, that would get rid of w/e the walls have on it, and a hottank and bore should cost less then 250.00..really?
I'd jump on this just to build another b20vtec setup if i knew where this block was.
Old Jul 14, 2010 | 05:15 PM
00Red_SiR's Avatar
All Motor Mentor
The only potential problem is that the cylinder may be damaged deeper than a .5 over bore could correct. Hard to tell in the pictures but I damaged a piston/bore in my old b16a2 with nitrous and I couldn't bore it out enough to fix it, so I scraped it.
Old Jul 14, 2010 | 05:48 PM
flipldls's Avatar
was planning on going high compression b20vtec, and was hoping the walls would hold up?
Old Jul 14, 2010 | 05:49 PM
flipldls's Avatar
with a hot tanked and a hone?
Old Jul 14, 2010 | 05:50 PM
00Red_SiR's Avatar
All Motor Mentor
you could have 30:1 compression, that's not the problem. It's part throttle low rpm ignition timing (AKA- having a GOOD tune) that's responsible for most B20 motors, living or dieing on stock sleeves.
Old Jul 14, 2010 | 05:53 PM
flipldls's Avatar
from the picture it looks like it got scuffed up but pictures can be decieving lol. i figure it would save me money since i plan on rebuilding a b20. just worried about the walls maybe in a much worse case than they look.
Old Jul 14, 2010 | 06:31 PM
092eg6's Avatar
if the price is right and sleeves can b saved by going no more than 85mm then jump on it.
Old Jul 14, 2010 | 07:13 PM
jmart41791's Avatar
ask him if you can take it to a machine shop for inspection.
jdmintegragsr
Aug 14, 2007 10:00 AM
lakai_19
May 21, 2007 02:25 PM
LvN
10
Aug 7, 2006 01:23 AM
stepka001
Jun 9, 2006 10:08 AM
Rice Is Best
Dec 26, 2004 08:10 PM
