Difficulties in entering first gear..
Old Jul 14, 2010 | 03:56 AM
arrowhead_vtec's Avatar
Default Difficulties in entering first gear..
hey there fellow vtec-ers,
i drive a EK, with a transplanted 92' b16a engine in my car from an eg6. using a 4.4FD Y21 lsd gearbox.
recently i encounter some difficulties in entering my first gear. it only occurs when the car is stationary. when my car is kinda on the roll, it enters without any force. upon stationary (stopped at a traffic light, making a 3 points turn... etc), it requires some FORCE to push it into first gear, after that no problem.. only gear 1.... whats my problem? synchro?
Old Jul 14, 2010 | 06:12 AM
Former User's Avatar
Default Re: Difficulties in entering first gear..
You may need to adjust the clutch pedal height.
Old Jul 14, 2010 | 06:25 AM
Deviousjet's Avatar
Alot of times especially when your coming out of reverse your gears don't align. If you let off the brake and let the car roll a couple of inches then it will go into gear.
Old Jul 14, 2010 | 08:25 AM
paddle has been adjusted, still no avail.
deviousjet: so what your telling is, its normal?
Old Jul 14, 2010 | 12:02 PM
OneFire's Avatar
I have the same problem. Through research I've heard it can be fixed by changing out your transmission fluid. Although I havn't gotten around to doing mine so I really don't know. I've also read it could be a bent shift fork *shrugs*
To be safe though, whenever I'm stationary I'll clutch down and go through all the gears before putting it back into first. If it doesn't go into 1st I'll just go 2/3/4/5 then by that time it'll go into 1st no problem.
Ali F. Ahmad
Honda Civic (2006 - 2015)
Aug 6, 2017 01:50 AM
migueldiaz
Jul 30, 2011 04:41 PM
NDeySay
Jul 19, 2008 03:54 PM
