96 Del Sol/stock d16y8: Need help with CEL code 92/P0441 for EVAP system
Hello I have a 96delsol with a stock d16y8, it was running perfect and still is even with the cel.
I got code 92 and already changed the evap solenoid and drove it for like 30 minutes and it came back on.
Could it be a bad gas cap? Could my evap canister be blocked?
I like keeping my car without problems so any help is appreciated!
I had this issue with my 97 DELSOL! I fixed it this last week! Ok so, My charcoal canister was leaking flakes of coal into my purge solenoid throwing the code PO441 i could tell by taking off and opening up the purge value solenoid and looking closely around the edges. it almost looked like dust but it was enough to not let the value seal.
the fix...
1 spend $6 for a inline fuel filter with two male ends
2 cut the tube going from the charcoal canister to the valve
3 connect the fuel filter into the split
4 No more code!!!!
I hope this works 4 u let me know ^_^
the fix...
4 No more code!!!!
[713]
Oct 21, 2008 12:13 PM
1998_4dr_gsr
Apr 3, 2006 09:58 PM
