crx HF d16z6 swap with problems (No start problems)
Old Jul 12, 2010 | 10:20 PM
Cyote's Avatar
Default crx HF d16z6 swap with problems (No start problems)
ok well lets start form the top well why i swapped well the a**holes who sold me the car broke the driver side motor mount bolts into the block and the mount slipped and had the engine resting on the came gear!!!!!! so i decided to do a swap.
only engine i found was a d16z6 SOHC vtec mpfi obd1..... ok now not proper at allllll i dropped the engine in with a new timing belt and used the HF trany, stock obd0 ecu, HF intake manifold, HF obd0 Dizzy. so pretty much just used the z6 block and head. drove it for about 3 days without any problems. then the 4th day i was going over some railroad tracks and it shook the car really good and then it started back fireing all stupid just BAM BAM BAM so i parked it at a parking lot. i tried to restart it and it would crank give some minor back fires but wouldnt start. so i tried starting it while adjusting the dizzy and something. so towed it home and let it sit i figuired i fried the ecu and the dizzy because i did the swap halve ***.
so few days later i drive all over colorado and grab a obd0 to obd1 ecu jumper harness, 4 wire o2 sensor, TD42U obd1 dizzy, and it was suppose to be a p28 but i ended up getting a pr4 ecu(DOHC, OBD1, NON vtec)....yeah i know i called the guy up and he is like my freind has ran it on his d16 swap and its ran fine without a problem. well i was told it will run way rich..... so i said i have to try i need a car bad. so i put the pr4 ecu in with the jumper harness and dizzy and o2 also pu the stcok z6 intake manifold on. now i didnt know what black o2 wire was the ground and witch was the heater thing so i guessed :D rywire sad one of the black wires so IDK then i left the vtec unplugged and didnt do anything with the orange and blue wire that comes of the converter harness. i wired the knock sensor and the other o2 wires and thats it. O and i also put some 210cc High impacedent injectors off my 3000gt in there since i read that ecu runs the car rich... so all changes i did was
-put the d16z6 intake mani on (and TB)
-extended the map sensor wire to reach the z6 sensor on the TB
-extended the sensor wire that is on the back of the z6 intake manifold
-put the obd0 to obd1 jumper harness in
-wired in the o2 sensor( guessed on the black wires and the brown ecu wire wasnt brown but there was one wire comming off a brown wire so i wired it there)
-wired the knock sensor
-wired the td42u dizzy to the obd0 harness
now i tried to start it and wlee it didnt start......
-i pulled the rail and the injectors didnt shoot out gas
-so i pulled the injectors still no gas then pulled the hose from the fuel rail still no gas.
-checked for spark and no spark??(pulled plug and grounded out while cranking.
-pulled the pr4 and put the hf ecu in and it just cranked 2 without gas or spark...
-next i checked all the fueses
-then i found a relar right by the clutch foot rest spot (thought it was the main relay) but it wasn't clicking so after about 20 time of me turning the keys to and from the ignition position it started clicking. then gas started shooting out of the hose i had poped off.
-put everything back together and nothing again all crank no start(tried with pr4 ecu and the stock HF one)
-checked for spark an no spark
-pulled the rails with injectors and the injectors were shooting gas like they were suppose to
-then i found the real main relay and it clicks like its suppose to
-Now i see the check engine light will turn on and off in like 4 sec interval......
and this is where im at now i dont know what to check now........... im thinking its the dizzy but IDK is there a way to check the dizy?
Old Jul 12, 2010 | 11:54 PM
DCRB's Avatar
Default Re: crx HF d16z6 swap with problems (No start problems)
either way you can't run the hf ecu with obd1 parts, it wont work. the dizzy's put out different signals. you have to ground the service wire to count the codes. a long flash = ten, short flashes = one. example. my cel came on earlyer today. the code it threw was one long flash (ten) and seven short flashes (seven ones) which was code 17 for my vss.
on the o2 you're supposed to have two black wires, a green and a white for a stock o2 sensor. the blacks are ignition power and o2 heater. the green is ground and the white is the signal wire.
if i were you i'd get the dizzy tested, it could be bad. my swap wasn't starting due to no spark, and it ended up being more cost effetive for me to replace the dizzy than just the coil since it was old. you should also look into a new main relay.
Old Jul 13, 2010 | 07:55 AM
Cyote's Avatar
well i used the wire diagram off of rywire for the o2 so get the dizzy checked then?
Old Jul 13, 2010 | 08:32 AM
Cyote's Avatar
well the check engine light flashes 9 times fast fallowed by 5 slow flashes???????
Old Jul 13, 2010 | 09:05 AM
Cyote's Avatar
No wait it has 9 short flashes then a pause then 4 long flashes and a short one so its has a code 9 and 41?????? But it is always flashing if if i dont have it grounded....... has to be something with the 02 sensor right... maybe the colors on my harness are different then rywires??
Old Jul 13, 2010 | 09:19 AM
lunalink's Avatar
that Pr4 wont work. and are you using the resistor box?
even without the o2 sensor it should start with ease. but it seems as if you're getting no spark, as stated earlier check your dizzy.
i have a p06 thats chipped/socket-ed if you wanna trade/buy.
post pics of how your wiring to your dizzy is.
Old Jul 13, 2010 | 11:25 AM
Cyote's Avatar
im not sure if i have a resistor box because i get 12volts to the injectors so could i still have the 12v??? and on the dizzy i wired all the wires to the same matching colors except on was different on the obd0 side its a white wire and on the obd1 side its a yellow with green strip but the car should still start then even with the pr4?? what are you asking for the p06 chipped?? will it work with my engine??
Old Jul 13, 2010 | 12:58 PM
lunalink's Avatar
$80 shipped. yes the po6 will work i had it running my z6 swapped crx before i got my p28 and went with a B16 lol
this is what i used for my swap.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d-i-y-faq-obd-0-obd-1-pinouts-conversion-help-1319235/
I wasnt able to find the other one i used for the distributor wiring just google search it and it'll come out. i believe 2 wire placements are different since the ignition out put wire on the HF is located on the driver side shock tower apposed to rest of the models.
Old Jul 13, 2010 | 01:27 PM
vtecn8ive's Avatar
I"m not even going to read what you wrote.
Make sure you are using the HF engine harness, its different then another MPFI harness.
Old Jul 13, 2010 | 01:33 PM
lunalink's Avatar
^ ha ha i already posted that
Old Jul 13, 2010 | 02:16 PM
Cyote's Avatar
but none of this helps or dose it?? so its the ecu thats not giving the spark? or ???? im trying a new dizzy tonite ... and on that ecu u have can i use stock HF injectors?? or i wired the distributor wrong ......
Old Jul 13, 2010 | 02:18 PM
lunalink's Avatar
if you're using stock injectors ( obd0-HF ) you MUST use a resistor box
other than that yes
and did you not read my previous post or did you?
Old Jul 13, 2010 | 05:03 PM
Cyote's Avatar
other than that yes
will i read it but dont get what your saying so the color wires on the hf dizzy is diffrent then all others??
Old Jul 13, 2010 | 08:07 PM
ef9ridda's Avatar
get a fresh wire harness....
Old Jul 13, 2010 | 08:10 PM
vtecn8ive's Avatar
I read what you wrote, and you should definitely get the right parts and go from there. Stop half-assing it and do **** right.
Did you solder and heat shrink your wiring?
Old Jul 15, 2010 | 11:03 AM
Cyote's Avatar
changed out dizzy and it starts. so i cant run the pr4 then? even with smaller injectors??
Old Jul 16, 2010 | 01:18 AM
Cyote's Avatar
or could i run a p28 socketed for 22psi????
Old Jul 18, 2010 | 02:52 AM
Cyote's Avatar
Can anyone tell me the exact pis on the obd1 side for all 4 o2 wires?? i cant figure out witch goes to what and am just guessing.(the harness i have has different colors then whats on rywire)
Old Jul 19, 2010 | 10:36 PM
Cyote's Avatar
any ways well i got a p28 ecu but.... it ran better with the hf ecu and dizzy???? WTF and if i wot it it smokes when i stop or for a while after???? and i have a cheack engine light but i dont know what the hell pins to connect to read it because all the wires are different colors then whats on rywire.... I havent hooked up v-tec either could that be it??
Old Jul 19, 2010 | 11:34 PM
lunalink's Avatar
if you dont have evereything hooked up the ECU will throw the codes
Old Jul 22, 2010 | 10:18 PM
Cyote's Avatar
well wired in v-tec and it runs good just still has check engine light and its code 14 ????? and dose this car have a knock sensor???
Old Jul 22, 2010 | 10:55 PM
lunalink's Avatar
14 is iacv i believe
tallicafanatik
Apr 12, 2011 04:34 PM
hfcrx88
Dec 10, 2007 12:30 AM
KamikazeRacinz
12
Apr 9, 2003 07:44 PM
IamVtec
Aug 29, 2002 09:58 PM
