Fresh gsr crank grind & balance need bearing advise LOOK !
Old Jul 11, 2010 | 02:03 PM
99gsvtec's Avatar
Default Fresh gsr crank grind & balance need bearing advise LOOK !
They ground the crank 0.25 (0.010)
Heres what journals spec out to Mains 54.75mm/(2.1555in) Rods 44.75m /(1.7620in) Wanted to make sure that ACL race bearings (0.010)/0.25mm would indeed be correct size
I ran duraglide oem spec bearings in my current gsr, but new build is gonna be 82mm Cp 11.0.1 c/r b18c1 eagle h-beam rods, acl race bearings, fully built port & polished p72 head ITR valvetrain Crower titanium retainers, Skunk2 Tuner 2 cams, Undecided if Im gonna run cam gears I have brand new skunk2s but car Is gonna be tunned by Churches again or Do it dyno I like the look of the greddy/toda blue timing belts cut valve covers & exposed cam gears, but this is my daily & I live in the worst state for owning a hopped up Honda CA anyways also have portmatched 68mm skunk2 t/b & intake manifold, 01 H22 injectors,Aem FPR/rail Hondata heatshield, walbro 255, Act streelite / flywheel hd pressure plate & disc 96 spec ITR tranny hasport axles, innovative billet mounts all wrapped up in a 1 owner 99 dc2 aiming for 225 on dynapack made 208 last dyno non-ported head, 60mm exh, apexi intake, new set-up. 2.5" mandrel bent cat back magnaflow resonator/muffler, custome 3" tube courtesy of K&N BPI velocity stack w/K&N 98 ITR header/JDM CAT. Only reason for build car uses oil smokes a lil either piston rings or valve guides either way, have these parts readily avail so ya back to the bearings much input greatly appreciated I dont have an oem repair manual that has specs
Old Jul 11, 2010 | 06:12 PM
stumpyf4's Avatar
Default Re: Fresh gsr crank grind & balance need bearing advise LOOK !
Did you get the crank nitrided after the grinding?
If not I would get a used crank and use OEM bearings according to the colour chart. Green all the way across usually doesn't cut it.
Old Jul 11, 2010 | 06:58 PM
99gsvtec's Avatar
It was a very mild grind why would they consider doing the job for me if it will not be reliable ? Why does it need to be re-nitrided if the bearings is what takes the abuse ? Why would they sell.25 bearings as well ?
Old Jul 11, 2010 | 07:23 PM
b20vtech's Avatar
just fyi, honda crank has a special coating they put on the crank for reliability/longevity, if that coating has been taken off by grinding, ur crank will still work but will not last as long as a crank that has the coating. get a use crank thats still good u will save yourself some headache for doing that.
Old Jul 11, 2010 | 09:53 PM
99gsvtec's Avatar
You guys say get another crank lightly I just spent $105.00 on acl bearings $187 on machine work & balance cant afford to just **** can the crank, it wasnt really bad before the grind just wanted it perfect, cant I just get it coated or something feel like they dont make -0.25 bearings for a reason
Old Jul 11, 2010 | 10:02 PM
Gregsteggy's Avatar
Ask the people that ground ur crank if they recoated if after grinding it
Old Jul 11, 2010 | 10:07 PM
99gsvtec's Avatar
I know they didnt
check out what clevite has to say im within safe zone
https://honda-tech.com/forums/showth...da+crankshafts
Old Jul 11, 2010 | 10:29 PM
99gsvtec's Avatar
Old Jul 11, 2010 | 10:51 PM
Gregsteggy's Avatar
I have only micro polished a crank man I really don't know a lot but if in the safe zone like u say then put that thing back together and and go smoke some ls1s
Old Jul 11, 2010 | 10:52 PM
99gsvtec's Avatar
haha maybe a handfull of mustangs dont know about vetts lol
Old Jul 11, 2010 | 11:00 PM
Gregsteggy's Avatar
Hay I love my tegra but I also have a 03 cobra so I wouldn't go that far dream big lol.
I hope ur build works out for u and u know if all els fells in the end stroke it just save the pennies I did
Old Jul 11, 2010 | 11:04 PM
99gsvtec's Avatar
buddy has 03 s2000 on aem tunning all bolt ons gets my current engine by 2-3 cars he ran an 03 gt with vortec s/c got beat by 2-3 cars I think ill get the s2000 with the new engine but its hard to find a stock cobra so ya haha Ill stay within my means lol not gonna expect to beat 400hp+ car lol
Old Jul 11, 2010 | 11:07 PM
Gregsteggy's Avatar
My na build ran pretty even with them till the top end of thing and it was over cobra walks hard.what all are u doing to this build.
Old Jul 11, 2010 | 11:09 PM
99gsvtec's Avatar
Old Jul 11, 2010 | 11:17 PM
Gregsteggy's Avatar
Very nice comp is low for a na car u car run pump gas all the way up to 13.0.1 if u want to stay na save up for stroked kit it's better that sex!!!!!
Old Jul 12, 2010 | 07:17 AM
projectTeG's Avatar
you must not know anytihng about a N/a engine.
Jack the compression yo and be mad fast!@!!
his compression is perfect for n/a.
as far as the crank goes, the heat treating honda does only goes so far into the surface. one removed it needs to be retreated and recoated.
Old Jul 12, 2010 | 07:29 AM
Gregsteggy's Avatar
Well he has everything needed to be fasted by raing the copmpress
Old Jul 12, 2010 | 08:11 AM
99gsvtec's Avatar
Wasnt raised by much I have jdm b18c gsr in the car which yields at 10.6.1 I believe & now its 11.0.1 will help but port & polished head should make a difference along with my fresh intake & exhaust set up, before the exh was bottlenecked & filter was a little small the pleats wernt that big on the apexi intake
mayfly
May 17, 2012 02:45 PM
OrangeTeggy
11
Feb 1, 2011 05:55 PM
94eh2
Oct 19, 2009 11:52 AM
91(si)hatchey
15
Apr 28, 2009 07:35 AM
da6vtec
Oct 10, 2001 01:54 AM
