RUNNING LEAN!!!
give a little bit more details about your setup.
Where are you running lean ? RPM, vaccum reading ( or boost ).
stock/aftermarket fuel pressure regulator ?
450 injectors, wired correctly ( need resistor box ? for your setup ).
Hard to say, but if you are stock setup ( I dont see why you would have 450s )and everything else normal, you would run VERY RICH .
14b with crome chip(a friend did it)
5k and boost
stock
yes it is and it runs rich everywhere but there
WALBORO ON THE WAY!!
5k and boost
stock
It could be 2 things.
I would probably say that where you are running lean there is a dip in the injector MS to boost you are running.
this can be due to a few things:
-Was the chip tuned specifically for your setup ( aka your motor , turbo , IC,injector setup you currently have ? )
-But if you are boosted, I Would definitely upgrade the fuel pump.
you also forgot to say what motor ?
d16y8, b16,b18b ?
I have seen a few lean spots with "generic"chips installed for boost setups in the vtec cross over.
d16y8, b16,b18b ?
If you are cloning chips from a buddy, try to get your setup as close to his as possible.
Ask him if he has a fuel pressure regulator, and if he does what psi he is running.
IF hes on oem FPR , then you are good.
sounds like u need a fuel pump, and a tune for your own set up. not your buddies.
Every engine acts differently.. so you will need to tune to your set up. Why you threw on 450cc's on a OE pump doesnt make sense. Sounds like you need a Fuel pressure regulator also. I would run @ 45psi and re-tune.
igorka_91
Apr 4, 2011 10:11 AM
