bilstein shock
Old Jul 7, 2010 | 04:28 PM
thundernoodle's Avatar
Default bilstein shock
why wont the rears go in!?!?!? Ive triedd everything the tube iss too big. wht d y d to fit them in?
Old Jul 7, 2010 | 06:02 PM
94rs-turbo's Avatar
Default Re: bilstein shock
I'm guessing you mean into the LCA's?
Old Jul 7, 2010 | 06:11 PM
Dave-ROR's Avatar
?? what exactly are you having a problem with?
Old Jul 7, 2010 | 06:17 PM
well I got the shock in by dropping the lca. it wouldnt go in at ffirst because the tube is too big. So i dropped the lca. now it all bolts except for the bolt that goes to the hub, the screw side is offfby 1/2 inch. it goess in but doesnt ffind the threads. andd my keyboard is ddyin lol.
Old Jul 7, 2010 | 08:59 PM
94rs-turbo's Avatar
lol ok well it sounds like you just having normal install issues because I'm guessing you never done this before
try taking off the 14mm bolt from the upper control arm from the trailing arm, that will give you more flexibility and after you got the bottom bolts started, with some elbow greese put the upper bolt back in(use a jack if needed to raise the trailing arm)
on a side note its usually easier to just start the the bolts in the threads, not tightening them all down one by one, after everything is in place go over all the bolts and tighten them down. doing this will give you more flexibility and less tension making your work earier for you
Old Jul 7, 2010 | 09:17 PM
dmxbmx's Avatar
i know this has nothing to do with your problem but im currently running the same shocks in my car and i dont know if you know this but if you send bilsteen your shocks and springs they will customize the shocks for you. they redo the the gas pressure, shock travel ect. i had them do it on mine and the ride is amazing. just thought id throw my 2 cents in
Old Jul 7, 2010 | 10:57 PM
racebum's Avatar
the one big advantage the have over koni. much cheaper revalving
Old Jul 9, 2010 | 02:33 AM
got it to work guys. thanks for the help!
Old Jul 9, 2010 | 02:10 PM
Devon M's Avatar
Let me know how it rides, because I will be buying these soon. Did you buy the regular or the sport?
Old Jul 9, 2010 | 02:28 PM
Dave-ROR's Avatar
Sports = ITR
HD = Non-ITR
They don't make HDs for the ITR rear LCA, and they don't make Sports for the non-ITR rear LCA.
Old Jul 9, 2010 | 05:37 PM
sports. dave is right. i made the mistake of ordering the HD's before realizing they wern't for an R. It rides nice and firm. Much better than my blown stockers. I cant make that good of a compairison but the bilsteins do send a bit more bumps through the cabin but they are nice and stiff and handleing has deffinately improved.
Old Jul 10, 2010 | 03:54 PM
Devon M's Avatar
Oh, good to know so I don't order the wrong ones. I was worried about them being too firm because I DD my R. One of my stocks is blown and the car rides pretty bad. Thanks for the info.
JDMjackyboy
Jun 5, 2011 08:15 PM
IntegraR0064
Jul 28, 2010 09:38 AM
Easy Eddy
Aug 18, 2006 01:05 PM
M@
May 17, 2005 04:35 PM
Ragezero76
18
Sep 22, 2002 04:23 AM
